My 48 v 1000 watt ebike kit isnt working!
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 4:53pm
I'm going to post an email thread below that explains my situatuon. Basically the motor isn't responding at all to the throttle. The lights are green on the throttle but the motor just makes a small tick sound. The wheel is difficult to turn and is cogging. Someone said its a shorted phase wire. I wonder if there's something wrong with the controller.
I don't have a very good multimeter to test anything. I can borrow one from a friend.
How do I locate the problem???? Do I need a multimeter?
ronbrown629   10 mW
Re: My 48 v 1000 watt ebike kit isnt working!
Post by ronbrown629 » Jan 04 2017 4:59pm
I lifted the bike off the ground and the motor ran fine but when I placed it back on the ground it sputtered and stopped. It felt like it accrelerating too much too quicky and something broke. I feel like it was the load on the bike which caused it.
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 6:13pm
? Hi
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 6:31pm
Y?? ????
Ykick   100 GW
Post by Ykick » Jan 04 2017 6:32pm
No need to PM me. Start here - http://www.ebikes.ca/learn/troubleshooting.html
And if you want more in depth help read the noob threads stickied around here and follow the often repeated basic advice.
- Frank Sinatra
Dumsterdave   100 W
Post by Dumsterdave » Jan 04 2017 6:34pm
Why did you PM me?
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 7:20pm
OK people quick update
I unplugged everything between the controller and motor.
I spin the wheel and the cogging stopped! !!
So does this is mean the controller is at fault?
I spun the wheel before disconnecting everything and it did cog but now it's not
More updates coming
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 7:30pm
I think I found the problem
Everything is unolugged right now.
I have three phase wires.(blue green and yellow)
When the yellow one is plugged in the cogging starts when it's UNPLUGGED it stops.
The blue and green wires have no effect on the cogging.
The yellow phase wire is the problem and it could be inside the controller.
The next step is to find out if its in the controller or motor .
spinningmagnets   100 GW
Post by spinningmagnets » Jan 04 2017 9:05pm
I sympathise with the situation you are in, Ron. We all started somewhere, and it is very frustrating when there is no clear cause for an issue.
I don't know if a $15 Digital Multi-Meter (DMM) will help with this particular problem, but you will need one someday, and getting one now is a good start.
Second, throttles are pretty cheap, and I recommend that you purchase one from the same exact vendor so that the two throttles are the same, and the connectors are identical. It's not often that the throttle is the problem, but...it is the easiest component to swap-out and test. You unplug the mounted throttle, plug in the second throttle, lift the rear wheel off the ground, and then spin the second throttle in your hand. If both throttles had tested previously to work fine, then this test "should" show if the issue is the throttle or not. A one-minute test.
I have a small 6-FET sensorless controller from Lyen, and a larger 12-FET sensorless controller from em3ev. With either one, when I plug it in, I only need to plug in the three thick phase wires that power the motor. Almost all common ebike motors and controllers use hall sensors. This means that five very thin wires will also be coming out of the motor (three thick wires, and five thin wires).
There might be a problem with the hall sensors, and swapping-in a sensorless controller is a good way to test that. If a motor doesn't work with the stock hall-sensored controller, but it works fine with a sensorless controller? Then it is not the motor itself. It could be the hall sensors inside the motor (there are three). it could be the wires between the hall sensors and the controller (pinched wires that are shorting is a common problem), and...it could be a problem with the hall-sensor portion inside the controller.
If you get a sensorless controller for testing purposes, the throttle connector and the three phase wires will likely NOT have the same connectors on their wires, so...you may need to get a soldering iron and swap the connectors out for something that's easy to get, cheap, and works well. After soldering-on new connectors, you will need heat-shrink insulation over the new connectors.
I know you may be on a tight budget, but...right now this is the best I can do. You'll have to save up your money to buy parts to make each step needed...one at a time.
https://www.electricbike.com/connectors ... tle-motor/
https://www.electricbike.com/matching-c ... ontroller/
https://www.electricbike.com/water-proo ... -shooting/
LewTwo   100 kW
Post by LewTwo » Jan 04 2017 10:15pm
Ykick wrote:No need to PM me. Start here - http://www.ebikes.ca/learn/troubleshooting.html And if you want more in depth help read the noob threads stickied around here and follow the often repeated basic advice.
I think he may have PMed a number of random people. He is from somewhere around New Britain Township, PA.
MTB, Front hub, 48 Volt (4 SLA Batteries),
Seems to had it running on 29 December the same day he created this GoFundMe project
https://www.gofundme.com/electric-bike-project
"I want to build an electric bike. I don't really need that much money. I need 1200 but I'm only asking for 800. Here's a parts list of the things I will be purchasing. Gmail me if you want an electric bike a single I can help you make it happen. I will use this to commute to work. Maybe I can help some homeless people build some ebikes. All I ask is you chip in 1 dollar and your good!"
I may be getting old and cynical but I am getting suspicious.
https://www.youtube.com/watch?v=zkLXI-sVi7E
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 10:44pm
I am from Southampton Pennsylvania.
I am using 4 sla in the meantime.
Ykick   100 GW
Post by Ykick » Jan 04 2017 10:55pm
Behaves like shorted MOSFET (yellow phase) so what did the troubleshooting guide reveal? http://www.ebikes.ca/documents/BlownMosfets.pdf
- Frank Sinatra
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 11:04pm
Just by the looks of my controller I think its not the controller.
I think I did the trouble shoot guide incorreclty. Its probably my cheap multimeter.
The fact that it doesnt coffee when everything is disconnected means its cooking from the controller???
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 11:07pm
No need to look at any of my other videos.
They don't relate to the problem and why are you suspicious?
Ykick   100 GW
Post by Ykick » Jan 04 2017 11:16pm
ronbrown629 wrote:Just by the looks of my controller I think its not the controller.
Slow down, calm down, take a deep breath and pay attention to details. Otherwise this isn't gonna work.
"no cogging" when everything's disconnected from controller tends to point towards the controller.
ronbrown629 wrote:No need to look at any of my other videos.
Unsolicited mass PM's tend to raise suspicion. That was uncool and improper, IMO.
- Frank Sinatra
ronbrown629   10 mW
Post by ronbrown629 » Jan 04 2017 11:17pm
Here's a video of my controller.
https://youtu.be/HKKYjgTLOww
Ykick   100 GW
Post by Ykick » Jan 04 2017 11:30pm
Here's a couple I made demonstrating expected Ohm meter behaviors with good controller MOSFETs:
https://www.youtube.com/watch?v=SFrJ9Uh2GM0
Follow up using a different scale on the meter:
https://www.youtube.com/watch?v=ezTYcY-hZOU
- Frank Sinatra
ronbrown629   10 mW
Post by ronbrown629 » Jan 05 2017 12:15am
Hey buddy
As I'm writing this I haven't checked out your video yet but appreciate and will watch it.
I'll also post a video of my test
For the continuity test I noticed an audible beep from my multimeter when the yellow phase was connected to ground.
ronbrown629   10 mW
Post by ronbrown629 » Jan 05 2017 12:31am
Its confirmed its a mosfet!!!!
I had my multimeter on the wrong setting.
Dauntless   100 GW
Post by Dauntless » Jan 05 2017 1:44am
ronbrown629 wrote:Here's a video of my controller.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
ronbrown629   10 mW
Post by ronbrown629 » Jan 05 2017 3:24am
Here's link to my mosfet test. I don't know how to attach videos directly.
I didn't do the reverse direction in the video because the test came good.
Now how do I find out which mosfet it is?
There seems to be 15 fets total and theyre grouped in a strange way.
There's a standard screw above each one.
Once its identified, how do I replace it?? ?
arkmundi   1 GW
1 GW
Post by arkmundi » Jan 05 2017 4:24am
:?: Whose eBike kit did you buy? And have you connected with the manufacturer? Is there a warranty? Can they service, or provide assistance? Might they provide a troubleshooting guide? Do they have replacement parts available, like a new controller? :?:
Ykick   100 GW
Post by Ykick » Jan 05 2017 6:17am
Good work Ron.
Successfully replacing MOSFETs is NOT beginner stuff. Have you performed component rework before? If not, chances of success are slim to none.
And even if you do successfully replace shorted MOSFETs do you know why they died? If not, the same failure could happen again?
Is the wiring from the motor damaged and/or nicked up in any way? A momentary phase wire short is all it needs to blow MOSFETs. Perhaps a Hall Sensor signal failed which led to operating the motor “out of sync” which is another way for phase power MOSFETs to be damaged.
I think warranty service/replacement from the vendor is probably your best course of action. Assuming there hasn’t been some sort of physical damage to the motor wiring?
There’s cheap controllers around and with some careful study and learning, it’s possible to rewire a generic controller to work with your motor. But, that’s going to require some patience and understanding about how to determine phase power and hall sensor combinations.
Or, buy a sensor less controller as the man in green font already mentioned.
What was going on before this happened? Were you riding? Did the motor start feeling funning, making noise, low power? Did it fall over?
No hard feelings from me about the PM but some folks might not feel as charitable? Could be a good idea in this thread to acknowledge that you learned your lesson and it won’t happen again?
Good luck.
P.S. to attach videos you only need the identifier code from youtube address to the video - like this for example: HKKYjgTLOww
Paste that in between the [youtube][/youtube] brackets found in the edit toolbar above.
- Frank Sinatra
dogman dan   100 GW
Post by dogman dan » Jan 05 2017 7:36am
If you bought this new,, they owe you a controller. It blew a fet right away.
