magura mt5e higo bbs02
barnaby81   1 mW
Post by barnaby81 » Jan 09 2017 6:44pm
I've had my etrike nearly a year now and have been managing with hydraulic non ebrakes and the bafang hydraulic break sensor cable tied to the breaks. this has not been hard but in winter with large gloves this has been hard. i have also wanted to stop better.
i treated myself to some magura mt5e's in the january sale which have just arrived. having opened the box i see they have red connections when i need yellow (standard colour for bbsXX parts i believed). Could somebody enlighten me how i can use them or are they going back?
many thanks
Ykick   100 GW
Re: magura mt5e higo bbs02
Post by Ykick » Jan 09 2017 7:05pm
Have you heard about someone using mt5e as direct plug-in for BBSXX drives?
BBS02 uses a magnetically actuated “Hall sensor” which pulls signal high up to about 4V.
All I can find about the levers you have say “mechanical switch” so I would assume it’s just an open/close switch. I think you’ll need a little more circuitry to operate the Bafang brake inhibit?
But I do agree the Bafang is much nicer experience with working brake inhibits. I finally dug out the sensors from the supplied stock Bafang cable levers and glued them to my Magura hydro rim brake housing along with a carefully placed magnet on the lever.
- Frank Sinatra
amberwolf   100 GW
Post by amberwolf » Jan 09 2017 7:15pm
Ykick wrote:BBS02 uses a magnetically actuated “Hall sensor” which pulls signal high up to about 4V.
If it just pulls it up, then you just put the switch between signal and 5v, rather than signal and ground.
If it pulls it down, do it the other way.
barnaby81   1 mW
Post by barnaby81 » Jan 09 2017 7:19pm
you may well be right. i looked at the mechanical cut off levers that came with the middrive and they just had a pressure switch. i thought magura had just put a pressure switch in too. looking at the levers they have. it just seems they have ended their wire with a red higo connector when bafang use yellow connectors for brakes.
Are their any hydraulic ebrakes that end in yellow higo connectors?
Ykick   100 GW
Post by Ykick » Jan 09 2017 7:20pm
amberwolf wrote: If it just pulls it up, then you just put the switch between signal and 5v, rather than signal and ground.
I tried that and it didn't work. Seems it didn't care for the Hall supply voltage? I didn't work much more on that approach once I started digging into the stock Bafang levers. And of course, those allowed me to retain the Higo connectors which aren't friendly to rework either.
- Frank Sinatra
barnaby81   1 mW
Post by barnaby81 » Jan 09 2017 7:36pm
After squinting at some photos am i right in thinking Tektro Dorado HD-E710 have yellow connectors at the end of them? i have also noticed i can buy my yellow connector hydraulic brake magnet with a red connector instead.
Ykick   100 GW
Post by Ykick » Jan 09 2017 7:59pm
barnaby81 wrote:After squinting at some photos am i right in thinking Tektro Dorado HD-E710 have yellow connectors at the end of them? i have also noticed i can buy my yellow connector hydraulic brake magnet with a red connector instead.
They appear to be Bafang compatible:
Read here:
http://dillengerelectricbikes.com.au/sp ... e-set.html
- Frank Sinatra
docw009   100 kW
Post by docw009 » Jan 10 2017 11:01am
On the Higo brake connectors that I've seen, red is two pin and three is three pin. My BBS02 is three pin.
The third pin is +5 volts, not necessarily needed for "low level" brakes. I wonder if the 2 pin red male connectors will fit into a 3 pin yellow female. It would make sense to me that they would.
barnaby81   1 mW
Post by barnaby81 » Jan 10 2017 5:26pm
your right about pins and colours and you can wonder no more, they don't fit together
docw009   100 kW
Post by docw009 » Jan 11 2017 5:57pm
Yeah. I went onto the freezing cold garage and checked out my red and yellow brake connectors. Designed to be incompatible.
Shoestring   10 mW
Post by Shoestring » Jan 14 2017 9:39am
I am very interested in using these Magura brakes also. Are they compatible with the bbshd or not? would the 2 into 3 connector work ? Sorry to be a little "dense"
barnaby81   1 mW
Post by barnaby81 » Jan 14 2017 12:38pm
i was very keen on using them too but we can't. i dont think changing the connector would work. when my refund comes through i'll be buying tektro dorado's that have the three pronged connector
Shoestring   10 mW
Post by Shoestring » Jan 14 2017 2:14pm
I think they would work with my hub drive kit. the Tectro levers supplied are only two wires with an rca style connector. I did not want to lose my hydraulic brakes and I didn't want to use a mid drive with mechanical brakes. I think I'll ask the vendor if these brakes come with a 3pin connector from the factory.
barnaby81   1 mW
Post by barnaby81 » Jan 14 2017 5:46pm
I believe they will work fine with hub motors using two wired brakes
Shoestring   10 mW
Post by Shoestring » Jan 19 2017 5:52pm
Here is something interesting, following a link on luna's forum, I went to EMPowered cycles and they have a yellow higo connector for the Tectro ebrakes which have a 2 wire reed switch and are compatible with the BBSHD. I'm thinking with this connector, these Magura brakes might work. Anyone got a second opinion?
Montague P   1 mW
Post by Montague P » Jan 19 2017 6:45pm
Hi all
Ive been doing the same research today and came across the same issue. I have no idea if it will work with my bbs02. I noticed that these brakes are sold as either HIGO opener or HIGO closer do you think maybe barnaby81 just chose the wrong type. He got the HIGO Open when he should of got the close?
Depending on the price you can source them for they seem to be one of the best brakes on the market. See the link below they test both in a lab and on the track
http://enduro-mtb.com/en/best-mtb-disc-brake-can-buy/2/
barnaby81   1 mW
Post by barnaby81 » Jan 20 2017 6:59am
Magera brakes no matter opener or closer will not work as ecutoff.
Tektro dorado''s will and do work as ecutoff.
Magura are better brakes
Perth_ebiker   100 mW
Post by Perth_ebiker » Aug 22 2017 10:47am
Is this a done deal - Mt5es will not work as ecutoff where the controller (my Infineon) comes with yellow HIGO ?
Not the end of the world, but disappointing.
electricwheels.de   100 W
Post by electricwheels.de » Aug 22 2017 2:14pm
barnaby81 wrote:I treated myself to some magura mt5e's in the january sale which have just arrived. having opened the box i see they have red connections when i need yellow (standard colour for bbsXX parts i believed). Could somebody enlighten me how i can use them or are they going back?
There are HIGO-S3-B2-adapters available here
Custom made cables and wiring harnesses for e-bikes. HIGO and JULET connectors, extension cables and much more. World wide mail order.
e-bike-technologies webshop
Perth_ebiker   100 mW
Post by Perth_ebiker » Aug 25 2017 8:32am
Anyone tried those adaptors ? Quite expensive in Aussie dollars if they don't work.
atarijedi   100 W
Post by atarijedi » Aug 25 2017 6:48pm
Perth_ebiker wrote:Anyone tried those adaptors ? Quite expensive in Aussie dollars if they don't work.
I don't know about the adapters, but I've bought HIGO cables from Reinhard (who owns ebike technologies) and they worked great. I would trust him that the cables work.
Perth_ebiker   100 mW
Post by Perth_ebiker » Aug 25 2017 8:44pm
Thanks. I emailed him overnight and explained what i was hoping to achieve (Magura MT5e) and Infineon controller w/ ebrake cutoff. Hopefully he responds in the affirmative, And I'll buy them
Adam271226   1 µW
Post by Adam271226 » May 16 2018 6:45pm
Hi, I found a relatively easy solution for using Magura two pin Red connectors with the 3 pin yellow connectors used on Bafang without cutting off connector all together or purchasing adapters.
I located which pin was voltage (used only for Hall effect switches) and which pins were used for "contact" type switches like one in Magura lever.
Pins in Magura connector are 1/3 of the rotation off from pins in Bafang connector.
In order to line them properly I removed the alignment pin from the Magura connector with an exacto blade.
Once the alignment pin was removed, I rotated the Magura connector so that one of the metal pins was at 6 o'clock position, second pin was at approximately 2 o'clock position and the removed alignment pin was at about 10 o'clock position.
With the pin at 6 oclock position, I made a reference mark on the outside of the connector at 12 oclock position with a sharpie. Then I extended that mark to the body of the connector using white paint marker.
This mark will be used to line up red male connector with the arrow on the yellow female connector.
Care must be taken when cutting off the alignment pin. One can cut through entire connector wall or fingers or bend pins.
I was surprised to find out that plastic was somewhat brittle and once I made score mark on both sides, the pin came out with out much difficulty.
Care must also be taken with making reference mark, if not exact pins will be bent. Some force is required to fully insert HIGO connectors so be precise with making new alignment mark because you will not know if extra force is due to normal connection or misaligned pins.
Completed Connection
reference marks view 2
reference mark view
Pin Diagram
atarijedi   100 W
Post by atarijedi » May 19 2018 1:03pm
Check out the ebike-technologies.de website, they make an adapter.
https://www.e-bike-technologies.de/inde ... go-s3-b2-a
afieldsmd   1 µW
Post by afieldsmd » May 23 2018 10:07am
Adam271226 wrote:
May 16 2018 6:45pm
I assume this worked?
Matt Hughes at Empowered bicycle is a good resource. He doesn’t have the Tektro brakes in stock, but he encouraged me to cut off the adaptor from my mechanical brakes, and solder them to the wires from the Magura handles. He said discard the 5v wire, and use the blue and black. Didn’t matter which way you connected them as one is a ground and it’s juat a switch.
