Hi guys,
My first post here. I plan to build my first ebike that I want to use for long rides ( maybe up to 60 miles or so ) along the beach, mixed terrain, small grassy hils, etc.
something of that nature:
I already have a Superior bike with 29" wheels that I plan to convert to electric.
Two things trouble me the most:
Wheels / tires, which I think might be too narrow for going on mixed terrain, so I could either
1. get 29/2.25" tires on the rims that I already have
[strike]2. get 27.5 plus ( 2.8" - 3" wide ) wheels with tires and try to get them onto this frame
3. get 27.5 plus ( 2.8" - 3" wide ) wheel for the back and a fatter one, supposedly 4" , with a new fork for the front[/strike]
edit: appears that 27.5+ wheels cost like a new bike. so crossing this option out.
4. forget about the current frame and get a new farbike to convert it
which of this options would you suggest?
as for the motor and battery, I don't need to go very fast, but might need some torque to assent some hills.
I though that a BAFANG/8FUN geared rear 48v 500w with a 15Amp controller might be a good start.
I found this motor for about 120$
if I understand correctly, 500w is it continuous output, while for a short time ( like getting up a hill ), it could output 48v * 15A = 720w , right?
What do you think of this? Is it a good idea, or should I go with a more powerfull, direct drive motor?
... while on the other hand, I see here mostly direct drive 48v1000w motors are suggested. something,like this maybe?
