Hardergamer
- Joined
- Jan 7, 2017
- Messages
- 103
Hi all, i am looking for sum good heat absorbing paint, as the inside of my hub motors side plates are unpainted, what would you use... and where from in the UK/EU?
And has any one added sum more mass to the inside of there DD motors? as i'm playing with the idea of adding a 1" thick aluminium plate to each side of the stater of my MXUS v3 motor (cut to fit) as an heat sponge, set in thermally conductive epoxy?.. as inadvertently Doctorbass did by water cooling his motor, with out connecting his water cooling up, he made it allot more heat stable under power! ?
I really need to finish reading "Definitive Tests on the Heating and Cooling of Hub Motor" this is only part of my cooling plans, as i'm adding external heat sinks and FF also..
