why is my stand stripping the plate that holds apart
ClintBX   1 kW
Post by ClintBX » Mar 19 2017 5:04am
Hi EPFMs,
So I recently pit on a 2 legged stand on my ebike. I've been looking forward to having a reliable stand. I a lot of food deliveries on bike and it'd a hassle having always lean the bike on a wall or something. My work has gotten a lot easier since I've installed it but it'd not perfect because the plate that I've billed the stand to is flimsy and keeps bending.
Now, its starting to shear the metal away. I know that this is gasping to just break of entirely and I won't be able to have my stand anymore.
The problem is that the plate can't handle the weight and every time I use the stand it bends from the weight. I have to bend it back because the bike becomes unstable and that's making it worse.
I'm stuck four answers to fix this. Does anyone have any idea for this? The stand itself is excellent quality. It's just that plate. Is they're anything I could attach to replace the plate that is sturdier out something?
Clinton
MadRhino   100 GW
Re: why is my stand stripping the plate that holds apart
Post by MadRhino » Mar 19 2017 9:20am
Big washers would help, even better custom made in hardened steel to match the stand's plate shape. Make sure it is only the plate itself and not the welded joint that is bending, for this would mean short term failure anyway.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
torker   1 MW
Post by torker » Mar 19 2017 9:50am
It looks like it is about to rip off the frame. I would get a piece of steel about 1/8 inch thick and make it wide enough to drill 8 holes and mount with ubolts. If this won't be too wide and hang up on something. Since the weight is pushing up you "might" get away with riveting or bolting/screwing it on but that means holes in the frame. I would ubolt it.
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 36 v x 20 amps
Specialized FSR Comp 9C 6*10 48v x 30 amps
Ykick   100 GW
Post by Ykick » Mar 19 2017 10:38am
That thin bracket was never intended to mount/carry a big heavy dual stand.
We put one of those a coworkers eBike with similar frame and after a few months riding along, he felt like he hit something big in the road but didn't see anything. Couple minutes later his tire went flat - still scratching his head he walked to work where I noticed the heavy dual stand, like this one, had ripped the thin cheesy mounting plate completely from the frame. Yes, the rear tire had rolled over it causing the flat tire.
Live and learn....
- Frank Sinatra
ScooterMan101   10 MW
Post by ScooterMan101 » Mar 19 2017 11:14am
It is time to go visit your local and trusted ... Welder.
It looks like a steel frame , which is good.
You could have a thicker plate welded in place of the current one. but another option is two plates , one on top and one on the bottom. then have a longer bolt from the stand that will go through both top and bottom plate.
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
spinningmagnets   100 GW
Post by spinningmagnets » Mar 19 2017 11:29am
You just need to spread the weight out by adding a steel plate under the stock plate (might require a longer bolt, easy to do). I would start with and edger blade, steel, available...and cheap. Cut it shorter with a $20 angle-grinder from harbor freight. New at home depot for $3. I have a used one that is already the right length, free if you pay postage.
melodious   100 kW
Post by melodious » Mar 19 2017 11:30am
https://www.trekbikes.com/us/en_US/equi ... d/p/12772/
I've been doing ok since moving the stand to the rear. Depending on how much is loaded in the back though. I'd say anything around 30 lbs. of stuff in the back of the bike will hold. The bike won't stand straight up with this stand though.
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
teklektik   10 GW
Post by teklektik » Mar 19 2017 1:55pm
spinningmagnets wrote:You just need to spread the weight out by adding a steel plate under the stock plate (might require a longer bolt, easy to do). I would start with and edger blade, steel, available...and cheap. Cut it shorter with a $20 angle-grinder from harbor freight. New at home depot for $3. I have a used one that is already the right length, free if you pay postage.
That solution cannot work.
The failure is from a twisting force on the bottom plate from the stand being forward of the plate. This is causing a downward tear so a reinforcing sister plate under the existing plate will do little if anything. Similarly, washers are unlikely to offer a solution.
As mentioned above, this needs either a thicker plate welded on to reinforce the existing plate, or a second plate bolted on over the top of the chain stays to prevent the existing lower plate from twisting down and away. In that second case, a spacer, length of pipe, or hard wooden block between the plates and the thickness of the stays would be a good plan. You can trim off that funky tab to ease fitment and just use a longer bolt to hold the plate/spacer/plate sandwich together. An alternative to the spacer would be a second reinforcing plate as SM described underneath so the present plate was doing little more than locating the bolt relative to the frame.
(click to enlarge)
markz   100 GW
Post by markz » Mar 20 2017 11:36pm
Home depot sells metal to a certain thickness, anything larger then there are commonly metal stores in commercial and industrial parks, a quick google helps. Metal Superstore is a chain.
MadRhino   100 GW
Post by MadRhino » Mar 21 2017 12:41am
Now I see that it is the bike's plate that is not strong enough. You need 2 plates that are wider, so they can hold on the frame tubes. There are some stands that have that kind of mount already.
Current bikes
Street:
Dirt:
ClintBX   1 kW
Post by ClintBX » Mar 21 2017 12:55am
MadRhino, that would be ideal. I'm taking up SM's on the plates. I think I'll do a below and above mount with plates. If they're wide enough.
haulincolin   10 W
Post by haulincolin » Mar 21 2017 9:58pm
Yep, I've done this job a few times for people. Welding a plate to match the existing one on top of the chain stays fixes it up real nice.
ClintBX   1 kW
Post by ClintBX » May 15 2017 11:48am
Hey guys,
Just an update on this.
I've ended up ordering a second stand with that top plate support. Its better but not perfect.
Now, the top plate doesn't want to stay put and slowly swivel out of place with use.
I've tried using pieces of rubber to keep it still. It's an improvement but it still does it.
And now, I can't tighten (or loosen) the bolt anymore because it's stripped out.
Anyway, any ideas how I can get this to stay in place? Short of welding? (Though it might have to come to that)
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » May 15 2017 4:11pm
ClintBX wrote:Hey guys,
There are definitely ways to affix something without welding, but they all have some type of compromise.
I just found this new tool called the Haywire Klamper. It will use wire to bind nearly any 2 things. I would say holes drilled in the plates would allow you to wrap them to the top and bottom stays. Some spray paint right over it and you won't even notice it.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
slomoshun   1 mW
Post by slomoshun » May 15 2017 4:22pm
ClintBX wrote:...Now, the top plate doesn't want to stay put and slowly swivel out of place with use....
If your bike has a thin gauge sidestand mounting plate it is important that the extended legs of the twin-stand touch ground as close to directly under the plate as possible. Some twin stands contact the ground a bit forward which creates a twisting torque on the plate. I've had good luck with my <50# bike using the Pletscher which locates the ground/stand fulcrum closer to the plate. Their stand also has shoes that register on the chain stays to prevent the swivel problem.
k.i.s.s.
