Recumbent Bicycle Source
I like mounting my battery on the rear rack (Use front motors) and this configuration balances the bike nicely for me and I don't have handling problems.
I recently purchased a back up battery For extended Range.
Battery: 9" x 5.75" x 3.25" 8lbs.
I don't always need 24AH of capacity, but there are times I'd like to carry a second battery. It won't fit in the main bag with the existing battery.
I'm thinking the easiest solution would be to hang a Pannier specifically for the battery on the rack when I wanted to take a trip with more range. Easy to put on the bike, and easy to take off. I charge my batteries off the bike. When the capacity of Battery 1 is used up... I'd just stop, and then connect this backup battery and continue on. Most Paniers I'm finding are quite deep which would lower the center of gravity (Good thing), but also quite big and I have nothing else I really want to put in the bag. I'm thinking I'd rather have something that was more of a rectangular that would hold the battery in a horizontal position than just dropping vertical into a deep bag. But I'm open to suggestions.
Anyone carrying batteries in a Panier?
What brands are you using?
Any downside to this method?
Padding?
Padding?
