Swe
On my new front 14 mm hub motor with IS disc mount fork, I can't get standard shimano brake adapters to fit. If I use 180 mm rotor and adapter the brake will only be able to touch the edge of the rotor.
The fork has "lawyers lips" and the motor axle is 14mm. I have no normal wheel to compare with (maybe my fork is odd?) but I think the problem is that the 14 mm axle makes the center of the wheel axle to be off center enough to make this problem.
Is this a common problem or have I something very strange here?
I think my solution will be to but the brake adpter (IS to Post) upside down (making it to short) and then use longer bolts and a nut or similar as distance. And maybe I can file the inside of the fork edges to make the axle go a little deeper, but that will only give a mm or so.
