I will give my real world numbers of my DD motor and maybe it can help you.
I ride a mountain bike in a city with lots of stops and starts, afternoon headwinds depending on direction, not much peddling and average about 27 watts per mile and about 12 mph by the time I am able to get through the city. So for me to go 60 miles around my city I would need a battery of about 1620WH. Since I roll at 36v that would be about a 45Ah battery. (1620w / 36v = 45ah)........
or.....
I could use less watts. So if I set my bike (throttle or controller) to only allow me to use 1/3 of 27 watts which would limit me to about 8mph wot on the flats before stop and go city driving, but it would extend my range so that a 15ah battery could cover it. It would just take 3 times longer to get there. (for me that is 15ah x 36v = 540Wh) (depending on stop lights and other reasons to stop.)
So 60 miles on a 15ah battery is possible if you go slow. Any peddling you do is a bonus.
Your 1200 wh battery should take you 44 miles on it's own, limit your controller to say 18 amps and you should be able to do it with moderate peddling.
Just remember, as stated above, limiting you watt usage is only one part of a ton of variables....ike type of bike you are riding, weight you are pushing, terrain, wind, temperature, amount of stops and starts needed etc.
How many volts is your DD motor?
