Buying BBS02 parts off craigslist
tomdfrommi   10 µW
10 µW
Post by tomdfrommi » May 27 2017 4:11am
https://detroit.craigslist.org/okl/bik/6108771806.html
I am going to buy the E-Bike parts off this bike for $350. Does this seem like a good deal?
It is a 48V frame mounted battery and a BBS02 mid drive motor. I'd by the whole bike for 900 but the frame is too large for me (20" frame and I am only 5'6").
Thought I would ask for a second opinion before I shelled out 350 bucks.
Thanks in advance.
footloose   10 kW
Re: Buying BBS02 parts off craigslist
Post by footloose » May 27 2017 8:32am
tomdfrommi wrote: I am going to buy the E-Bike parts off this bike for $350. Does this seem like a good deal?
Used is always kind of a crapshoot, especially battery. But this seems like a pretty reasonable deal. Especially if you can test ride the bike or at least see and hear it running before purchase. New equivalent e-bike parts would set you back about a grand... so you'd save enough $$ that even if you need to replace battery at some point in future you could come out ahead.
Short answer -- If it were in my town I'd go look at it, and if it appeared and sounded good I'd probably buy the electrics.
tomdfrommi   10 µW
10 µW
Post by tomdfrommi » May 27 2017 9:08am
If the parts are already taken off is it still possible to listen for issues (grinding etc.)?
Marin   1 kW
Post by Marin » May 27 2017 10:03am
yes you could plug it all together and carefully operate motor on the bench
Marin ex-rental hybrid with 48v bionx...sold
Specialized hardrock with magic pie 4-5
Lunacycle with l/r mid drive coming soon
Kona Caldera with QS 30H (maybe), and phase runner
Giant Yukon bbs02
Kona Abra Cadabra bbshd
Wildfire fat bike bbshd
footloose   10 kW
Post by footloose » May 27 2017 1:07pm
If I recall correctly, when you test the components off the bike...
the system will work with throttle input, but may show an
error code on the display meaning something like "no signal from
speed sensor" -- i.e., the little magnet that mounts on the spokes
isn't passing by the signal pickup and generating signal.
Might be Error 21 if I remember right?
Not a problem, and you might be able to fool it simply by
hand waving the magnet back and forth by the senor.
Raged   1 kW
Post by Raged » May 27 2017 10:24pm
footloose wrote:If I recall correctly, when you test the components off the bike...
Yeah error 21 is the speed sensor. It still works as a zero load test though.
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
tomdfrommi   10 µW
10 µW
Post by tomdfrommi » May 28 2017 4:14am
Thank you for the replies, it is appreciated.
Ended up buying the whole bike. Little big on me but for what I plan on using it for it will be good. Rode it to work this morning, was awesome. :D
footloose   10 kW
Post by footloose » May 28 2017 8:28am
That's great!
Funny thing I've been noticing about bike sizing.
In an electric bike I actually like a bit larger frame than I would in a pure pedal bike.
So that bike might turn out to be perfect size.
