Can't find any pictures of it anywhere on Google I attached some pictures. I got it working and got KT controller with lcd 3 but when the watts go above 900 it cuts out I got a 36v 8ah lithium battery
It looks pretty generic and should work with most controllers. 900W might be a bit much for a 8Ahr battery. I don't think the cutting out problem would be due to the motor.
Ok thanks I thought it would be the battery but I waiting for a 48v 20ah lifepo4 battery should be much faster at the moment I get 21 mph but the torque is not good at all it gets to 21 mph but really slow
That thing looks crazy wide! I bet you can pump some wattage into that puppy
noise reduction angled laminated stator similar to crystlye but its not their motor
900watts at 36v is 25a that could be all your controller and battery can put out. If you want to make it faster get a better controller and increase to 48 or 72v
For the motor you can get off and put your hand on the motor for over heating. I think that motor could take 1,500 watts. Hills ,sand and lugging create Heat. Small battery.
