Signguy-Everett
I built my ebike a few years ago 48V 1000W rear hub and have put over 100 hrs on it and over 1750 miles commuting. I have a 48V 15 Amp Lion battery. In the past couple of days it has started acting up. The display (like this one http://preview.tinyurl.com/y9ztecxt) is going blank for no apparent reason and I loose all power. Today it was on for a second then shut off. I unplug the battery, plug it back in and hit the middle power button and it flashes on for a second then off. I turned my battery off and on and it would sometimes flash on for second then off.
Is the display bad? Is the controller going bad? I looked at all the connections and everything was tight and secure. Anything else I should try to look at? The bike has been bulletproof until this past week when it has started acting up.
Thanks for your help.
