Supreme Kay
Hello ebikers
I am shopping for a BMS for my 48 volts (11.6ah) battery made of Panasonic NCF18650PF. I will be using the battery with my 1000 watts motor (My controller is a sinewave 48 volt with a max output current of 26 amp). I am a newbie with BMS.
Does how many MOSFETs is a BMS made of matter (4 MOSFETs, 6 MOSFETs)?
Does temperature sensor matter in a BMS?
My pack is in a hailong battery case. Therefore, I have to use a small BMS to make it fit
Here is a link to my battery case:
https://www.aliexpress.com/item/Down-tube-electric-bike-battery-case-and-lithium-ion-storage-box-for-36V-or-48V-electric/32796605576.html?spm=a2g0s.9042311.0.0.sTSUnS
I came across a few BMS here are the links:
1- eBay (This BMS has 4 Mosfets)
http://www.ebay.com/itm/Balance-Protect-Module-BMS-PCM-to-13S-48V-Li-ion-Li-Po-E-bike-Battery-30A-SMB73/222599474650?_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D46086%26meid%3D1ea695f7b950442db07878b4a6ffc31a%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D253100490111&_trksid=p2047675.c100009.m1982
2- eBay (This BMS has 6 Mosfets)
http://www.ebay.com/itm/35A-BMS-PCB-board-PCM-w-Balance-for-e-bike-ebicycle-48V-13S-Li-ion-Battery-Pack/172622220990?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
2- Aliexpress (This BMS has 4 Mosfets)
https://www.aliexpress.com/item/13S-48V-Li-ion-Lithium-Cell-30A-18650-Battery-Protection-BMS-PCM-Board-with-Balance-for/32722818521.html?spm=2114.search0104.3.57.d53Pqx&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10130_10068_10344_10342_10343_10340_10341_10307_10137_10060_10155_10154_10056_10055_10054_10059_100031_10099_10338_10339_10103_10102_440_10052_10053_10142_10107_10050_10051_10324_10325_10326_10084_513_10083_10080_10082_10081_10178_10110_10111_10112_10113_10114_143_10312_10313_10314_10078_10079_10073,searchweb201603_16,ppcSwitch_5&btsid=bfb56f3d-ba22-4e02-9802-ea2b6aab316d&algo_expid=969b7f26-9a77-4265-a518-34c004e1635d-7&algo_pvid=969b7f26-9a77-4265-a518-34c004e1635d
3- Aliexpress (This BMS has 6 Mosfets)
https://www.aliexpress.com/item/High-quality-48v-18A-bms-li-ion-lithium-13s-54-6v-smart-bms-system-polymer-battery/32815608739.html?spm=a2g0s.8937460.0.0.UuIYE2
Thank you in advance for your input
