Heated jacket for winter riding
steven7601   10 W
Post by steven7601 » Sep 17 2017 9:54pm
I am trying to build a heated jacket for winter riding
I am wanting to use a potentiometer to controll the current thus the amount of heat I already have the step down converter going from 100volts two 12volts at about 4amps I tried to just wire a potentiometer in line and turn it up and down but I think the current is still to high going threw the switch because I can see it spark inside the switch when I turn the knob can someone tell me what I need to do to make this work.
liveforphysics   100 GW
Re: Heated jacket for winter riding
Post by liveforphysics » Sep 18 2017 12:05am
I used carbon fiber yarn or "tow" in crimp connectora and silicone to mount it and made my own heated pants and jacket. I was a little surprised, but you only want about 50-100watts of heat over your whole body even in very cold weather.
amberwolf   100 GW
Post by amberwolf » Sep 18 2017 12:30am
Some other threads about heated clothing that may help:
https://endless-sphere.com/forums/searc ... mit=Search
There's some other threads not in the above that are in the list here:
though not all of the results are relevant.
d8veh   100 GW
Post by d8veh » Sep 18 2017 5:53am
Be careful. I made one a few years back, when I needed to do a 2 x 200 mile motorcycle ride in sub-zero temperatures. I used a 12v heated pad from a car seat, which I sewed into the back of my jacket. I tested it first. Sitting on its own it just got nicely warm. During the journey, it worked perfectly. Every time I felt a little cold, I pulled my shoulders forward and enjoyed the warmth of that pad. I had a thick woolen jersey between me and the jacket. I did the first leg down to my parents' house in the morning. At about 17:00, I could feel a little pricking sensation in my back, like when you get a strand of copper wire stuck in your clothes, so I lifted my tee-shirt and asked my mother to see if she could remove whatever was causing the problem. She said, "That's very strange, you have a great big square blister on your back". At no time did I feel anything hot, and it took about 6 hours before I felt the effects. I can't explain why I got burnt like that.
dogman dan   100 GW
Post by dogman dan » Sep 18 2017 6:47am
The old frog in the boiling water thing. Gradually lets himself boil because the heat increase was so gradual.
If the trip is shorter, perhaps some affordable battery powered heated socks on your chest?
To warm your hands and feet, add another layer to your torso. You can go very thick on vests without making it feel like you can't bend arms and legs. Old snow ski trick. If you overdo, easy to cool off with an unzip. Can't do that so easy if you are too thick on the pants. Just saying don't hesitate to pile on a down vest, double up pile vests, etc.
Of course, I assume you already upgraded hat, gloves, and shoes/socks, so you can't go much more there.
MadRhino   100 GW
Post by MadRhino » Sep 18 2017 8:38am
Feeling cold is more about tension than heat. I mean, when you can relax it does get much more comfortable. Sub zero here, is almost half of the year. Yet most riders are not wearing heated garment. They do on snowmobiles, because the rides are usually all day long trips. On a bike in the winter freezing weather, the rides are normally limited to the essential, or short sport trips.
Multi-layer clothing on your chest is enough to ride at -20 for an hour IMO. Keep your heart warm, and you won't freeze. Of course, face and extremities (hands and feet) must be well protected from wind chill. Frozen toes and knuckles are very painful when they defrost. :wink:
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
Raged   1 kW
Post by Raged » Sep 18 2017 12:53pm
Just get a heated jacket? Runs off a couple of lipo or a buck converter off your battery pack.
https://www.milwaukeetool.com/heated-gear
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
motomech   1 GW
1 GW
Post by motomech » Sep 18 2017 10:48pm
I made my own. I started w/ a reversible jacket that has pockets inside and out. I got some little "heat grids" from China and taped them to cardboard the size of the 2 inside chest pockets. They are powered by 2 sm. LiPoly bricks of 22.5V. that go in the inside hand-warmer pockets. Each has an alarm, but it never goes off. The batteries last hr.s, longer than my avg. ride. Works great, if anything, it gets too warm.
I also wired heated grips, using the type of grids that motorcyclists install under the grips. The non-throttle side works great, but I couldn't make the side w/ my half-twist throttle work. Intionaly, the one grip got too hot too hold on 22.5 V(I didn't use the 3-position resistor switch supplied w/ the kit), so I installed Grab-ON foam grips and the heat is perfect. I also like the foam grips.
Motomech
'07 GT Idive 4 4.0, Q100H 201 frt. mounted, 14S Multistar LiPoly, elifebike 9-FET 20A controller. Mean Well HLG-320H-54A, Crazy Bobs on Alex DM32's 21 to 22 MPH. viewtopic.php?f=3&t=28151&p=1373714&hilit=Idrive#p13737
