More ebike questions
wturber   10 MW
Re: More ebike questions
Post by wturber » Oct 20 2017 5:12pm
s4turn wrote: I've also ordered 2 more PAS sensors $4 or something, they have different mounting brackets
https://bmsbattery.com/ebike-kit/705-du ... results=67
I have one of those, but it is unclear how to mount it. I assume you just press it onto a crank spindle and then zip tie or otherwise secure the case to the frame/bottom bracket. Not sure if it goes on the chainring side or the non-chainring side.
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
s4turn   1 W
1 W
Post by s4turn » Oct 20 2017 6:02pm
from the picture in the link it looks like its on the left hand side
Buk___   10 kW
Post by Buk___ » Oct 20 2017 6:08pm
The second picture shows left side mounting; and this makes it look simple.
wturber   10 MW
Post by wturber » Oct 20 2017 6:37pm
Buk___ wrote: The second picture shows left side mounting; and this makes it look simple.
Doh! Never noticed that picture. But that's pretty much what I imagined, except facing the other way. It it is odd that the cable heads toward the front of the bike and that the body is not secured to the frame. Does orientation matter? If so, then I'd be inclined to put this on the crank side so the cable points back toward my electronics. And if actually installed as shown, the cable is the only thing keeping the body from spinning. Won't that put unnecessary strain on the cable?
docw009   100 kW
Post by docw009 » Oct 20 2017 10:06pm
I read that if you have a KT-controller with LCD-3 display, the C1 setting is for the PAS sensor. Use 00-02 for 5 magnet disks, and 05-07 for these V12 sensors with 12 magnets.
I also have one of these too. I'm not using it until one of my orange ones fails. I got it to work in test mode. Forgot which way I had to spin it,
d8veh   100 GW
Post by d8veh » Oct 21 2017 4:30am
It points backwards if you rotate it 180 deg!
It's fixed to the spline of the BB retainer sleeve, so it won't rotate in service, but can be inserted in more or less any position.
wturber   10 MW
Post by wturber » Oct 21 2017 10:27am
d8veh wrote: It points backwards if you rotate it 180 deg!
Good point. But I don't understand the point about the retainer sleeve. I started to install one of these just for grins when I replaced my bottom bracket. After pressing it onto the bottom bracket axle I couldn't see how anything was going to retain it. I'll take the crank off tonight and take another look. If still confused, I'll post pictures.
Oh - I was also not impressed by the moderate amount of friction in this device. It doesn't seem to spin very freely. Probably not a big deal, but it just seems wrong not to have that much friction. OTOH, maybe it wears in and spins more freely over time.
Buk___   10 kW
Post by Buk___ » Oct 21 2017 12:07pm
wturber wrote:Good point. But I don't understand the point about the retainer sleeve.
If you look at the right hand view in the second image from the top Image
The flutes on the outer circumference of the central boss push into the stationary part of the BB; and the curly prongs on the inner circumference grip the rotating shaft. Presumably the two (plastic) parts are not connected so prongs rotate the magnets and the flutes hold the body & sensors steady.
wturber   10 MW
Post by wturber » Oct 22 2017 3:30am
Makes perfect sense now. I didn't remember the second set of "prongs" and did not connect your mention of "splines" to the spline pattern that the bottom bracket install/remove tool engage. Sure enough, the second set of plastic prongs line up exactly with the splines on the spline tool and the device fits tightly onto the cup of the bottom bracket.
Thanks!
s4turn   1 W
1 W
Post by s4turn » Nov 01 2017 2:04am
got my new BMS today, wired it in!
havent taken my bike for a ride yet, suns down :( I need bike lights
but so far battery is still charging!
currently at 51.2v!!
its never charged this high, even when i reset the BMS last time. Use to stop at 47v!
exciting times :D
got the other 2 PAS sensors today too, can take some photos of them if people want
im not entirely sure I will use PAS sensors yet, I will just be stoked to have a working ebike.. after 6 weeks of waiting
s4turn   1 W
1 W
Post by s4turn » Nov 01 2017 4:47am
interesting, battery charges to 54v?
is that normal for a 48v battery?
Ykick   100 GW
Post by Ykick » Nov 01 2017 6:26am
s4turn wrote:interesting, battery charges to 54v?
Li-ion/poly 13S (48V) fully charged = 54.6V Practically empty = about 40V
- Frank Sinatra
d8veh   100 GW
Post by d8veh » Nov 01 2017 6:54am
Fit the PAS - it makes the bike so much better. I only use my throttle in exceptional circumstances like today to ride my bike to the doctor to sort out my bad foot. I can't pedal at the moment.
s4turn   1 W
1 W
Post by s4turn » Nov 01 2017 2:05pm
yeah thats the next thing I plan to do
got 3 PAS sensors now, just have to pick the best one :D
the cranks were really easy to fit (got the deore m590's)
Im still waiting for the brakes to come in too (got xt m8000's with 8" rotors for front and back arriving hopefully this week)
s4turn   1 W
1 W
Post by s4turn » Nov 02 2017 2:51am
took the ebike to work today
the bike is a beast!
was able to sit on 45 km/h on the way home :D
I am peddling a lot too, i find it weird not to
no cut outs or issues (touch wood!)
