Left hand motorcycle reservoir?
rg12
Post by rg12 » Jan 13, 2018 1:06 pm
Hey Guys,
I need help with my project of converting motorcycle brakes for my ebike.
I already chose calipers, discs, hoses and will 3d print and sent to cnc the caliper and disc adapters.
The problem is the brake levers as I need a right hand and a left hand but in motorcycles the left is the clutch so I'm having a problem finding the same model lever with reservoir for the left hand side.
I found this: https://www.ebay.com/itm/7-Color-Clutch ... fresh=true
Do you think it will work?
Does the left hand side for the clutch work different than the one intended for the brake?
Also, the set in the link looks great except I'm looking for shorter levers and I didn't find that in such a set, only on a single right hand reservoirs.
Would appreciate some help here :)
Mongoose EC-D 2007 (19" motocross wheels), 21s 10Ah LiPo, Greentime 72V 80A Controller, 12kg Hub Motor
MadRhino
10 GW
10 GW
Re: Left hand motorcycle reservoir?
Post by MadRhino » Jan 13, 2018 4:10 pm
Use Magura Gustav brake levers, or Hope M6. Those older big bicycle brakes have enough reservoir capacity and piston volume for average motorcycle brakes.
You could also use a hydro clutch lever for the brake of course. The link you posted is OK.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
