Blue wire on 5 wire LED throttle?
ebike11   10 kW
Post by ebike11 » Jan 29 2018 1:55am
Hi guys
I got this throttle without any instructions. Its a 5 wire led throttle.
3 wires are for the throttle itself. I touched the single yellow wire to positive which
shows the led voltage display. But where would the blue wire connect to?
Its for the key/lock.
Thanks!
https://imgur.com/a/HCbZX
dogman dan   100 GW
Re: Blue wire on 5 wire LED throttle?
Post by dogman dan » Jan 30 2018 8:44am
Its likely getting hot into the key on the pack voltage led display wire. Then the key switch goes back to the pack voltage "ignition" wire on the controller, if it has one. most but not all do.
Hook up that yellow wire, turn the key, and see what voltage you get back out of the key switch with a voltmeter.
