48 Volt Rear Hub Build
EbikeAus   100 W
Re: 48 Volt Rear Hub Build
Post by EbikeAus » Feb 15 2018 7:02pm
Thanks guys, can't wait to ride it :D
Choose LiFe 8)
May all your batteries be fully charged and perfectly balanced :P
EbikeAus   100 W
Post by EbikeAus » Feb 17 2018 8:11pm
Got the TAs done.
They ended up hand making them. Also a custom washer and 2 x stainless bolts cut to size. All for $50 AU.
Great job I reckon.
https://i.imgur.com/k65BjJO.jpg
https://imgur.com/a/KF00L
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Feb 18 2018 5:00am
And battery done. Just need connectors, I'm thinking XT60 or the Spark resistant XT90s look cool!
https://imgur.com/pmNylix
https://imgur.com/KPNtKSB
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Feb 19 2018 4:18am
Ok, I hooked it all up and the back wheel spins. Happy days :)
Just have to finalise mounting the battery, controller and some cable management.. then should be golden.
Not sure whether to use the brake disconnects/ levers that came with the kit. Do you guys think this is a necessity?
Choose LiFe 8)
wturber   100 kW
Post by wturber » Feb 19 2018 3:49pm
EbikeAus wrote: โ†‘
Feb 19 2018 4:18am
If not the ones included in the kit, then some other scheme/system that cuts the power to the motor when the brakes are applied or your hands aren't on the handlebars etc.
There's a lot of torque from that motor and it can get out of control fast. Especially when you aren't sitting on the bike. Good use habits are probably the most important thing. But it'd be nice to know that grabbing a brake lever will disconnect power.
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
EbikeAus   100 W
Post by EbikeAus » Feb 19 2018 5:06pm
Good call!
Thanks for the reply, I will use them
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Feb 27 2018 4:09am
Hi all,
Have been super busy! Putting our hoise on the market soon and had heaps to do. I have found time to get out for a couple of rides on this build, around 20 kms clocked up so far.
Will post a completed photo soon.
It's running great and the battery is performing very well, have put a couple of small charges on it and all good.
I have a couple more batteries almost ready to build, 14s 5p LG HE2 and 14s 4p 25R more on those later.
One thing that's not great is the brakes. I'm using the levers that came with the kit and it looks like I need new cables with a larger barrel head?
Can anyone confirm this and do the kit levers use an 8mm barrel head?
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Mar 07 2018 5:54am
Here's a vid of my build.
Thanks for everyone's help/advice it's appreciated :D
https://youtu.be/OC5VsPVyxHk
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Mar 30 2018 12:45am
Updated photo of this build.
Absolutely loving it! Have around 150km on the clock now.
Couple of upgrades since this photo are Suntour NCX suspension seat post and Mirrycycle mirror.
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Mar 31 2018 12:23am
I just discovered a couple of other features the voilamart hub kit has...by accident :lol:
It's not mentioned in the very minimal manual but if you press and hold the down arrow on the button pad it goes into walk mode, so you can walk beside the bike and it propels itself, another long press to disengage.
Also if you press and hold top button it turns on headlight, if you have one. Yet to test this but I just bought some headlights so I may use it :)
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Apr 23 2018 2:39am
Went out for a 15km ride this afternoon, bike is going great.
55 km on flat. 40 km up hill without pedaling, so pretty happy with that.
I'm pretty sure i'll need to take the controller out of the bag though :( as it was almost too hot to touch, which will most likely kill it before too long.
One option I have thought of doing is cutting a vent hole in forward corner of triangle bag and one at other end to get some air flow over the controller. I saw this done somewhere on here but can't find it now.
Where would you mount the controllerif this was your bike?
Choose LiFe 8)
torker   1 MW
Post by torker » Apr 23 2018 6:24am
Looks tight but on the seatpost would make all the cabling nice and short. Might want to build a deflector for the mud/water. Or right in front of the battery bag, nice looking bike btw..
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
http://s18.photobucket.com/user/rolinfu ... t=3&page=1
EbikeAus   100 W
Post by EbikeAus » Apr 23 2018 4:00pm
torker wrote: โ†‘
Apr 23 2018 6:24am
I think the seatpost option will be out now as I've added a suntour ncx seatpost.
Might explore the front of bag option.
Thanks for that ๐Ÿ˜
Choose LiFe 8)
markz   100 GW
Post by markz » Apr 23 2018 6:51pm
How does that front mud guard help out?
I have a full length one thats a tad too narrow and rubs on tire.
EbikeAus   100 W
Post by EbikeAus » Apr 23 2018 7:43pm
markz wrote: โ†‘
Apr 23 2018 6:51pm
It's just for looks at this stage. ๐Ÿ˜†
Just coming out of a long hot and dry summer here. No wet stuff to speak of. I'll let you know if you like ๐Ÿ˜Š
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » Apr 25 2018 2:42am
I decided the best place for the controller is on the tube under the bag.
I hit it with a couple of coats of flat black. This brings the cables as close to the battery and bag as possible.
Not ideal but at least I won't fry the controller :)
I might add some silicone to the joints and where the wires come out just in case.
Choose LiFe 8)
Philaphlous   100 W
Post by Philaphlous » Apr 25 2018 5:13pm
How you like the suspension seat post? I haven't ridden my bike enough to test it out.
EbikeAus   100 W
Post by EbikeAus » Apr 25 2018 7:41pm
Philaphlous wrote: โ†‘
Apr 25 2018 5:13pm
I like it a lot so far. Takes a little getting used to but def makes a big difference!
Only downside is I have to find a new rear guard now as I can't attach to the seat post. :cry:
Choose LiFe 8)
Lurkin   100 kW
Post by Lurkin » Apr 26 2018 6:21am
Mudhugger guard would be super nice, but its a pretty expensive option.
A guard on the front wheel is the most effective way to keep water off the controller. Failing that a guard over the controller is an option.
If all else fails, and you are caught out in the rain - pinch a dog poo bag from a dog park + electrical tape = water tight....
EbikeAus   100 W
Post by EbikeAus » Apr 26 2018 6:53am
Lurkin wrote: โ†‘
Apr 26 2018 6:21am
Yes I've seen the mudhugger. If I can't find anything else i'll probably get one.
Great idea with the dog poo bag! 8)
Choose LiFe 8)
EbikeAus   100 W
Post by EbikeAus » May 14 2018 6:40am
Help I need new brakes!
I'm loving this bike but it has one major flaw!
I currently have mechanical discs and they suck. After using hydraulics on my Giant Roam conversion it's hard to be happy with mech discs.
I'm looking at these as a place to start
https://rover.ebay.com/rover/0/0/0?mpre ... 1848243345
I will probably replace the front first and keep the rear as it has the motor cut out switch.
Are there levers I can buy with the switch, I can only find them for bafang?
Or are they easy enough to diy?
Just saw these, has anyone used them?
https://rover.ebay.com/rover/0/0/0?mpre ... 3129487626
Choose LiFe 8)
Chalo   100 GW
Post by Chalo » May 14 2018 4:32pm
Are your mechanical discs generic cheap crap? There are good and horrible mechanical discs just like there are good and horrible hydraulics. (But if you give a hearty tug on the lines of both, you'll find that the mechanical ones work a lot better.)
(Also, you'll find that touching a cable to your brake rotor doesn't harm anything, while touching brake fluid to your rotor makes the brake very lame.).
Anyway, the cable brakes that are worth a damn these days are Avid BB7 and TRP Spyke. I'd try those before going for hydraulic, magnetic, pneumatic, optical, nuclear, or any other needlessly gizmodic brakes.
EbikeAus   100 W
Post by EbikeAus » May 14 2018 7:44pm
Chalo wrote: โ†‘
May 14 2018 4:32pm
Thanks mate ๐Ÿ˜ƒ
Yes I think they are a pretty basic shimano set.
It does seem to make more sense staying with mech discs, that's what I'll do.
So with the two models you mentioned do you know off hand which will have a thinner calliper body as I'm fairly tight between caliper body and motor?
I'll just order discs and calipers and use the cut off levers that came with the kit for now. Would like some nicer ones at some stage if they can be had.
Choose LiFe 8)
