Undervolting cheap Chinese direct drive brushless 36V 500W?
cdevidal
Would it be possible to put two 12V SLAs on a kit like this or must I run these at 36V?
https://www.amazon.com/JAXPETY-Electric-Bicycle-Cycle-Conversion/dp/B0761QYCKM/ref=cm_cr_othr_d_product_top?ie=UTF8
Oops should have read further in the search results. Found this. Nevermind.
A different controller with more amps, could get you the same watts for climbing the hills, but at 36v. But it is the tends to make the motor hot way to do it. At some point, you cross a line and too much amps just cooks a motor. It depends on a lot of variables what happens in the real world.
(Source)
Makes sense. Lower voltage equals higher current and blammo, dead motor.
