BPM2 or Q128 conversion kit? (Copied from my post to Reddit)
09Klr650   10 mW
Post by 09Klr650 » Mar 28 2018 4:21pm
One last question for everyone here. Planning on pulling the trigger on my conversion kit order from BMS Battery and cannot decide between the two. This is for a front-wheel application. I see Q128 comes with a 9 mosfet 450W controller and the BPM2 a 12 mosfet controller. Also the Q128 is listed 4-500W vs 500W BPM2. Other than that and the fact the BMP2 does not specifically state rim brake compatible there seems little to justify the $50 difference between the two. Any experiences and comments regarding the two?
Given the shipping cost I would like to get things right the first time! Thank you.
molybdenum   100 W
Re: BPM2 or Q128 conversion kit? (Copied from my post to Reddit)
Post by molybdenum » Mar 28 2018 5:07pm
I'm not sure what controller you reference. Perhaps you could specify the models you are considering, and whether you want to use throttle/PAS or both. I say this because I have the S12S "500W" controller and it pushes 1000W on max setting under throttle. Its minimum setting is just over 500W without option to reduce any further. This is under throttle response, and the PAS settings should allow greater reduction in wattage.
2012 Kona Dew Deluxe, Q128C and 9spd cassette, S12S sinewave controller, 48V Panasonic battery
09Klr650   10 mW
Post by 09Klr650 » Mar 28 2018 9:31pm
Unfortunately that is about all that BMS lists on their website for information. I am inferring from the information they list that for the Q128 they are using their S-KU95 and for the BPM2 the S-KU125. I plan on using both the PAS and throttle.
S-KU95 (https://bmsbattery.com/ebike-kit/801-s- ... e-kit.html)
S-KU125 (https://bmsbattery.com/controller/806-s ... e-kit.html)
BPM2 kit (https://bmsbattery.com/ebike-kit/346-ba ... e-kit.html)
Q128 kit (https://bmsbattery.com/ebike-kit/346-ba ... e-kit.html)
Hwy89   1 kW
Post by Hwy89 » Mar 28 2018 9:59pm
Can't make a side by side comparison for you. Last year I bought the Q128h 201 rpm motor and a S12S 500W Torque Simulation Sine Wave Controller. The two work together seamlessly and I am very happy with the combo. Very smooth, very quiet, and an amazing amount of torque to get up the hills.
I had an unfortunate occurance this winter when my cover leaked litterly filling the controller with water plus I had left the battery plugged in. The battery was flat dead and the controller a soggy burnt up mess. I built a new battery pack and ordered another S12s controller and I'm back to enjoying the Q128.
motomech   1 GW
1 GW
Post by motomech » Mar 28 2018 10:32pm
molybdenum wrote:
Mar 28 2018 5:07pm
But there is an option: cut one of the two shunts.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
viewtopic.php?f=3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
viewtopic.php?f=3&t=49691&p=1378484#p1378484
molybdenum   100 W
Post by molybdenum » Mar 29 2018 2:07am
motomech wrote:
Mar 28 2018 10:32pm
molybdenum wrote:
Mar 28 2018 5:07pm
Very true, cut one shunt and halve the amps. You can even file away some of the shunt(s) to get a more refined reduction...
As for the S-KU95, little is known about it except that it works with the LED810 Meter Panel and it is new to BMSB. As a sinewave controller, the S12S runs the motor whisper quiet and it can be programmed through the SLCD3/SLCD5 interface. I couldn't find anything on BMSB or otherwise regarding programming parameters for the S-KU95. Maybe someone here knows something about it? Certainly, an option is to buy the motor, S12S and SLCD3 display separately from BMSB I'll bet these aren't much more expensive than the Q128 kit.
motomech   1 GW
1 GW
Post by motomech » Mar 29 2018 4:14am
I filed a shunt once and didn't get all the metal particles cleaned out and as soon as I powered it up, it zapped the ICB:(
Motomech
09Klr650   10 mW
Post by 09Klr650 » Mar 29 2018 9:14am
Thank you all, but we may be digressing a bit. As controllers are easily replaced why not concentrate on the motor itself? Is the BPM2 worth the extra cost?
docw009   10 kW
Post by docw009 » Mar 29 2018 10:33am
I think BMSbattery feels the BPM2 can handle more power as they bundle the kit with a 30A controller, whereas the Q128 comes with a 22A controller. Neither controller supports an LCD, just the 810 LED display which means you have 3 PAS levels. My first ebike kit came with an 810, and the pedal assist is a bit abrupt at low bike speeds. I'm used to it, but it scares newbies, especially if they haven't ridden a bike in years. The torque simulation controllers feel better, in part because the first assist level is pretty mild.
Bafang ships close to a million motors annually. I think it's a "big name" in ebikes because of what they also do in the mid drive market. If this was a one time buy for me. i'd be willing to pay a little more for the bigger controller, possible higher power, and "name" and get the BPM2. However, I've put together a few kits, and now I look at lower cost. I'm pretty sure a Q128H would work. I bought a bare Q128H last December ($140 shipped). Not installed yet.
For someone in the USA, the ebikeling 500W front motor kit for $209 shipped on ebay looks pretty good to me. Comes with SW900 LCD and a 22A controller. Might not be available in 700cc, but 26" is available. I bought one of those too. While also not installed, I have tested it. It runs on 48V. My first ebike kit in 2015 came from him. Same motor. Has worked fine.
09Klr650   10 mW
Post by 09Klr650 » Mar 29 2018 11:18am
docw009 wrote:
Mar 29 2018 10:33am
I considered this. They are also selling them on Amazon. However I have not been able to get a response from them about if this is only 36V as listed, or can also run at 48V. At the moment I have (4) 6S 10Ah 22.2V lipo from the recent HK sale. I probably should have went for the 3 or 4S combos but the cost-per-Wh for the 6S was very compelling.
Thank you.
-dg   1 kW
Post by -dg » Apr 13 2018 8:05am
One thing to keep in mind is that the BPM is bigger and heavier than the Q128. I haven't tried either although I have a partly completed bike with a rear BPM, but I'd be cautious about putting that much power and weight on a front wheel.
If simplicity worked, the world would be overrun with insects.
