3.9C cell with 28mΩ resistance?
rg12   10 kW
Post by rg12 » Apr 16 2018 4:58am
Hey Guys,
I measured the awesome Samsung 25R (8C) and it has 8mΩ resistance.
Then tested the LG M26 (3.9C) and it has 28mΩ resistance.
Is that normal for a 3.9C cell to have such high resistance?
All cells are new and tested on a few different batches and they all show the exact same numbers.
Mongoose EC-D 2007 (18" motocross wheels), 21s 10Ah LiPo, Greentime 72V 110A Controller (soldered shunt), 9kg Hub Motor
MadRhino   100 GW
Re: 3.9C cell with 28mΩ resistance?
Post by MadRhino » Apr 16 2018 6:09am
The state of charge and temperature does affect impedance of a cell. Those parameters should be measured equal, to compare 2 cells.
Then, both impedance readings that you have measured are within the manufacturers spec
Your Samsung cell impedance should be 7 to 16 m/ohm, 28 m/ohm after trip
If my memory is good, I recall your LG cell should be 60 m/ohm after trip. So, probably twice the impedance of the Samsung cell when in exact same state of charge and temperature.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
fechter   100 GW
Post by fechter » Apr 16 2018 8:51am
It might depend on how you are making the measurement too. AC measurements are pretty useless.
rg12   10 kW
Post by rg12 » Apr 17 2018 3:55am
It's a DC cell IR tester.
Both tested brand new, same temp, same state of charge.
Charged many from different batches (all new) and all have the same specs.
Can it be that a 4C cell has almost 4 times higher IR than 8C?
rg12   10 kW
Post by rg12 » Apr 21 2018 8:39am
rg12 wrote:
Apr 17 2018 3:55am
Bump...
MadRhino   100 GW
Post by MadRhino » Apr 22 2018 1:59am
rg12 wrote:
Apr 21 2018 8:39am
rg12 wrote:
Apr 17 2018 3:55am
Bump...
You will know when you pull 4C continuous off them. My guess is they will get hot.
Current bikes
parabellum   10 MW
Post by parabellum » Apr 22 2018 10:22pm
rg12 wrote:
Apr 21 2018 8:39am
rg12 wrote:
Apr 17 2018 3:55am
Bump...
Looks fine 3.2W waste heat on 25R and 2.9W waste heat on M26. M26 will have to tolerate it for double time span but area of the the cell is enough to dissipate it.
