Voltage boosters
sutty86   10 mW
Voltage boosters
Post by sutty86 » Apr 17 2018 5:20am
Anyone use these to charger there DIY batteries.
I have plenty of 12v 30a switching PSU about the house and these can be bought for £20 with a digital display allowing you to play with voltage and amps.
Closest charger here in the UK I've found is £50
The only problem I can think of with the booster is trying to case it I've been looking at the bst400 for my needs (14s)
fechter   100 GW
Re: Voltage boosters
Post by fechter » Apr 17 2018 3:55pm
I've seen a few people try them. The amp ratings given are generally exaggerated quite a bit. If you get one "rated" for about double what you want and use a cooling fan, it might work OK.
eCue   10 kW
Post by eCue » Apr 17 2018 8:44pm
sutty86 wrote:
Apr 17 2018 5:20am
You will need a voltage cut off or risk killing the batteries in a overcharging mishap
Solar charge station on wheels join the Revolution
amberwolf   100 GW
Post by amberwolf » Apr 18 2018 4:57am
