ScooterMan101
Who has a link or two of a rear hub that has both the 6 bolt holes for the disc rotor , and , a flange/holes for also bolting up a sprocket , both on the non drive side of a bicycle .
( For use with the mid-drive systems that use a jack shaft or just run the motor drive on the brake side of the bike. )
Are those hubs 135 mm dropout spacing or more ?
Is there a rear hub that does that and is the newer 12mm x 143 mm Through Axle system ?
