Endlesscube23
- Joined
- Apr 27, 2018
- Messages
- 3
Your mission, should you choose to accept it, is offering suggestions on a setup that would meet the following requirements:
1. Budget ~$1400
2. Approximate range: 40+ miles without pedaling. Edit: I could live with 30 miles on throttle and 40+ with minimum pedaling.
3. Top speed: ~30mph
4. Terrain: Mostly flat, urban commute.
5. Frame size: Suitable for someone over 6ft tall.
6. Load capacity: Capable of hauling a 230lb man + 30-40lbs of cargo.
7. Motor preference: Front hub.
8. I'll be able to charge the battery for 2-3 while away from home for extra range.
Thanks in advance, and I appreciate any additional insights.
Updated: I bought this 1200w 48v front hub kit from ebikeling.com
https://www.ebikeling.com/shop/electric-bike-48v-1200w-26-direct-drive-kit-2
Still looking for a battery that with enough power.
1. Budget ~$1400
