geosped
- Joined
- Mar 18, 2015
- Messages
- 258
I wanted to start a new build. I want to build a full suspension 29'er with a rear hub. My BMC Rear hub is on it's way out and will need to get something with a bit more umph to get my fat ass (250lbs) up those nasty hills. Any suggestions i'm more interested in torque that speed as this will be a purpose built heavy duty mountain bike. I would like to do most of the work my self so looking for suggestions.
Lynn 72 A Controller
MXUS 60V 29" 3000w Are there better options for rear hub kits? Any issues on a 29" wheel? Are there better options? Looking for rear hub sealed hub ONLY.
Battery pack's not sure was thinking 1650's custom made pack need to know what size pack would I need? Trail is about 10 miles but lots of climbing. What size pack would you recommend 10ah 15ah 20ah??? I'm thinking 15Ah pack.
My current rig is a
26" Full Suspension Giant Anthem bike with a BMC Rear hub motor, 72A Lynn controller, upgraded torque arms and 10Ah Zippy lipo pack consisting of 4 5000mah 25c 6S packs. I put 2 in series and those two in parallel to make a 10ah 12s pack. Unfortunately I believe I burned my hall sensor so looking for a new replacement. This setup has plenty of torque and speed for the type of riding I do but I dont think the BMC was setup to withstand 1800w for any extended period. Need something designed for the higher load's.
My current rig is a
