High Amperage BMS Reccomendation
jktobin1   1 mW
Post by jktobin1 » Jun 13 2018 9:28pm
I am currently working on an electric motorcycle project. The project consists of a 20s10p battery pack with a total voltage of 72 and a continuous discharge of 200A. The largest, high quality BMSs I could find for a 20s system were 150A. Looking a continuous discharge of 200A and a controller that will support up to 500A I'm trying to find a solution to use the BMSs during charge and discharging. I wanted to ask if I can connect multiple BMSs in parallel to possible double the maximum current? I have heard both sides of the story for using the BMSs for discharging and I will include a small section of what I have learned. I want to see if anyone has any recommendations or ideas for my setup. Any and all help is appreciated
BMS During Dishcarge:
-Balances cells during discharge and charge
-Allows shut down based on individual parallel groups rather than the battery as a whole
No BMS During Discharge:
-Allows the option for regenerative breaking (haven't been able to find a high amp model that will support that)
-ESC can limit current from the battery preventing over draw
amberwolf   100 GW
Re: High Amperage BMS Reccomendation
Post by amberwolf » Jun 14 2018 1:35am
Use a BMS with teh features you want *except* for it's discharge rating, and bypass it's output FETs. Instead, use the signal that would've turned those on and off, and drive a contactor instead, so the contactor does the battery cutoff.
Then you can also use the contactor for keyswitch/safety control, too.
You can also use the charge port's control line to shutoff the contactor during regen braking if the risk of overcharge is worse than the risk of braking power loss at a critical moment. (generally I'd rather momentarily overcharge the pack than lose braking at any time).
parabellum   10 MW
Post by parabellum » Jun 14 2018 1:36pm
Baron   100 W
Post by Baron » Jun 14 2018 2:05pm
you could split the battery into two 72V packs, each with their own BMS? which would cut the high amperage requirement in half
eee291   100 kW
Post by eee291 » Jun 14 2018 4:42pm
Who said you can't use regen with a typical china BMS?
I have tried about 20 Different models from Ebay,Aliexpress and Bestech, and you can do regen on all of them.
Also 72V 500A Controller continuous?
At such high discharge currents I wouldn't waste any more energy on heating mosfets. I would connect the battery to the controller with an High amp fuse and power only the controllers Ignition wire from a weak 20S 25A or so BMS.
You would just need a sort of relay switch connected to the BMS, since you need to switch the B+ to ignition.
Or another way would be to only connect the 12V DC-DC converter to the BMS, and then power the controller with 12V. Which at least works on Kelly Controllers, you will have to check with the Controller you are going to use.
amberwolf   100 GW
Post by amberwolf » Jun 14 2018 5:31pm
Baron wrote:
Jun 14 2018 2:05pm
And as soon as one cuts out for any reason, the other suddenly is supplying the whole current, and POOF.....
Rube   100 W
Post by Rube » Jun 14 2018 6:22pm
If you are willing to optimise the system for 16S you could use this product: https://www.energusps.com/shop/product/ ... 0a-750a-36
Discharge/Charge/Regen current 750A if used with external relays, current sensor and mounted on a heatsink.
amberwolf   100 GW
Post by amberwolf » Jun 14 2018 6:37pm
Any BMS could be used at any current level, regen, charge, discharge, etc., as long as external relays (contactors) are used. That's what I pointed out previously.
jktobin1   1 mW
Post by jktobin1 » Jul 16 2018 10:26am
Sorry for the late replay, I haven't had access to a computer that would let me log in. The BMS I have access to is the link on the bottom. According to the company's very spotty customer service they said it would not support regen braking. Is there a way to test this without hurting the bms because the customer service rep did not seem very confident in their answer?
Would you be able to provide a simple diagram for the wiring setup you are suggesting with using the contactor as a cut out? I believe I understand what you are saying but won't I still need to run the discharging current through the BMS in order for it to be able to sense the discharging current and send the signal to the contactor?
I'm pretty much looking for the most reliable solution with these parts. Here is a link to the motor I will be using as well. The pack will be a custom build of the LG HG2 batteries in a 20s10p configuration.
http://www.evdrives.com/product_p/mot-me0907.htm
http://kellycontroller.com/kls7275d24v- ... -1338.html
http://www.batterysupports.com/72v-84v- ... p-296.html
parabellum   10 MW
Post by parabellum » Jul 25 2018 8:58am
jktobin1 I would like to ask you some questions.
1)
What cells are you using?
2)
Desired peak current is? For how long, your estimation?
3)
Why would you balance during discharge?
4)
How much current do you think you get at regen?
Sunder   100 MW
Post by Sunder » Jul 26 2018 1:18am
jktobin1 wrote:
Jul 16 2018 10:26am
I bought a 12S BMS off those guys, but it was years ago. From memory, there is a common negative, but a separate charge and discharge port. This means that regen "isn't supported" because all energy will be coming back in from the "wrong" port. This can mean one of two things:
1. You can safely regen energy into there, but if regen over-voltages the cells, you're on your own.
2. You can't safely regen - reversing energy flow will blow the board.
My one was NOT damaged by charging through the discharge port. But remember this was nearly 7 years ago, they could have changed their designs since then.
For $99+shipping, I wouldn't recommend trying it out. I'd ask them whether "not supported" means that it won't protect the battery, or the BMS itself will be damaged.
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 Died... Electrified Ninja in Progress!
eCar: Mitsubishi Outlander PHEV... Warramty expired. Still not game!
eHouse: 6.2kw On-grid solar with battery backup coming soon!
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
artvk   100 mW
Post by artvk » Sep 17 2019 11:27pm
amberwolf wrote:
Jun 14 2018 6:37pm
Just curious how to connect BMS with this setup as I cannot find BMS match with my desire.
Any diagram would be appreciate.
Art
atarijedi   100 W
Post by atarijedi » Sep 19 2019 7:08am
If you are willing to spend the money, you could use the BMS24T from Chargery. It supports up to 24S, and up to however much current you want I believe. It uses 1 or 2 external contactors (relay) to control charging/discharging. So for 500A, you would just need a contactor that can support 500A, they sell them up to 600A.
Take a look at the manual on their website to see if it's what you want.
http://www.chargery.com/BMS24.asp
