Show your drinking and eating setup
cwah   10 GW
Post by cwah » Jun 15 2018 10:35am
Hello
I realised that often I wanted a drink while cycling. Or maybe eat a little something.
For very little weight added, I can now drink and drive:
https://www.dropbox.com/s/h073lh1xr1dr6 ... 8.jpg?dl=0
https://www.dropbox.com/s/6tdwd76r9j0dc ... 8.jpg?dl=0
What does you food set up looks like?
markz   100 GW
Re: Show your drinking and eating setup
Post by markz » Jun 15 2018 1:29pm
This is my setup.
MadRhino   100 GW
Post by MadRhino » Jun 15 2018 2:11pm
On two wheels, doing anything else than riding will get you more than your share of broken bones.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
cwah   10 GW
Post by cwah » Jun 15 2018 6:08pm
markz wrote:
Jun 15 2018 1:29pm
This is my setup.
Nice one. Similar to mine!
wturber   100 kW
Post by wturber » Jun 15 2018 6:49pm
MadRhino wrote:
Jun 15 2018 2:11pm
Yeah - so for commuting I replaced my regular bike water bottle with this. The key is the screw on cap. It removes the temptation. I can have a drink if I'm stopped and have both hands free. :)
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
John and Cecil   1 kW
Post by John and Cecil » Jun 15 2018 7:29pm
feed bag.jpeg (8.02 KiB) Viewed 859 times
dogman dan   100 GW
Post by dogman dan » Jun 18 2018 7:21am
Yeah, drinking while rolling is how I broke both collarbones. I carry a capped Gatorade bottle in my bottle cage now. And stop to get a sip.
John and Cecil   1 kW
Post by John and Cecil » Jun 18 2018 11:29am
Maybe a handlebar mounted bottle with a long plastic tube so you never need to take your hands off the grips and you can take a sip without looking away from the road?
wturber   100 kW
Post by wturber » Jun 18 2018 2:58pm
John and Cecil wrote:
Jun 18 2018 11:29am
There are enough stop signs and stop lights around so that I have no problem with the current setup. I'm not in a race. No big need to eat or drink while on the bike. And with our 90 degree mornings and evenings and 100+ degree days, I slam down about 12 ounces of cold water before heading out anyway. That slows down the onset of thirst pretty well.
P.S. Long before Camelbacks and the like, back in the mid 70's I rigged up a tube system on my Sears Free Spirit ten speed ( a BSO that somehow and amazingly was super useful as an actual bike - whodda thunk?!?) so that I could drink while riding - from a "straw" (pvc tubing) on the handlebars that went to one of my water bottles. It worked OK.
John and Cecil   1 kW
Post by John and Cecil » Jun 18 2018 4:30pm
We have 2 cooler saddle bags for 100 degree days. We load them up with ice water and both Cecil and I have evaporative cooling vests which we soak every 30-45 mins in the ice water. They worked really well on the motorcycle by drawing the heat out of you so I expect them to work well on the ebike too. Before I got one for Cecil he would squirm whenever we stopped at a red light, after he started wearing his cooling vest he never squirmed in his box again when riding out in the hot sun. It worked so well for him that I got one for myself. I have to build him a little convertible bimini top this year too.
cwah   10 GW
Post by cwah » Jun 19 2018 2:28am
Jun 18 2018 4:30pm
Wow. Do you have a picture of your setup with cooler bags?
trooper5707   100 mW
Post by trooper5707 » Jun 19 2018 7:49am
Many years ago, the military gave me a nice desert tan Camelbak. Worked great all through Iraq, and still use it to this day. Carries my water and has some extra storage room. Seem to have fallen out of favor these days. I used to see them on mountain bike trails all the time.
https://www.camelbak.com/en/packs/R0103 ... 6966e8bb48
Frey AM1000 - Speed Machine
Rad Rover - Work Horse
Rad mini - On the go
Home Brew Hub 1000W Hub build
Xiaomi M365
John and Cecil   1 kW
Post by John and Cecil » Jun 19 2018 9:36am
cwah wrote:
Jun 19 2018 2:28am
They are ScootR Logic saddlebags which are fairly inexpensive and lightweight insulated cooler bags. I have them mounted on Cecil's hardwood custom carrier, however they could probably be mounted as small pannier bags on the side of the rack as well. I believe the pair is rated to hold a 24 pack of 12 oz cans. They are nice for carrying gear too because since they are cooler bags they are also waterproof.
miro13car   1 MW
Post by miro13car » Jun 20 2018 4:15pm
Rising your head up to have a sip is a dangerous exercise, even more dangerous than talking on the phone.
markz   100 GW
Post by markz » Jun 20 2018 10:07pm
I want a battery powered refridgeration "pannier" so I can take it with me fishing.
Thermo-Electric Cooler the type used off of a 12V car system.
https://www.amazon.ca/Revesun-Thermoele ... B01LVUC7FL
I wonder though, how many Ah's it would eat up.
amberwolf   100 GW
Post by amberwolf » Jun 21 2018 12:10am
Years back, I had a peltier-type fridge with about a cubic foot and a half space inside, and IIRC it took 2 or 3 amps or more while running off it's 12v power supply; it ran a lot more than not, to keep stuff just about 60F inside, in a 90F+ environment. Adding a 5"+ computer case fan to cool teh peltier heatsink helped, letting the temperature get down another 10 degrees to around 50F, but power usage was a bit higher due to the fan, and it didn't change the duty cycle.
Might be some better stuff out there these days. More / thicker / better insulation would help; this thing was plastic with about 1" of styrofoam inside its' walls and door.
wturber   100 kW
Post by wturber » Jun 21 2018 12:45am
amberwolf wrote:
Jun 21 2018 12:10am
A quick survey of two similar small coollers shows a 4-5 amp draw or about 50 watts. That seems tolerable for a short trip, but then on a short trip, it isn't needed as much. On a long trip (more than two hours for instance), that kind of power draw seems a bit much. Though you could almost make up for it with a 2ft x 2ft 50 watt solar panel.
amberwolf   100 GW
Post by amberwolf » Jun 21 2018 1:08am
AFAIK, a "50 watt" panel will only get you 50w max at the best perfect illumination conditions at noon on the equator. ;)
If you need actual 50w at the load, you need to figure the efficiency hit between the panel and the load in whatever conversion electronics there are, and in the panel itself under teh conditions it'll actually be being used in, including the lighting and temperature. You might need at least 2-3 times as much panel as you think.
Then it only works in good direct sunlight, so it doesn't power anything if you are on your way home in evening/dark, and the cooler warms up after that point.
wturber   100 kW
Post by wturber » Jun 21 2018 1:48am
amberwolf wrote:
Jun 21 2018 1:08am
Yeah. I knew that "almost 50 watts" was probably optimistic, but I didn't realize it was that optimistic. A little digging and I'm inclined to agree that with a moving system you'd be doing well to get half the rated output on average.
In the evening we switch to pure battery and keep our samiches and sodie pops cool. Priorities. ;^)
John and Cecil   1 kW
Post by John and Cecil » Jun 21 2018 10:17am
I had a 12v plug in cooler once and it did not work very well. I tried a peltier cooler for a computer chip once and it consumed a lot of power and it also gave off a lot of extra heat in the process too. I don't recall how much power my cooler used but I preferred to carry small blocks of ice (cubes do not last as long).
What I have found that works best for day trips is to freeze the beverages that you plan on drinking on your trip and then put them in an insulated cooler or cooler bag to keep your food cold too. If the cooler is going to be in the sun put something reflective over it to keep the sun from heating it up. This is a very lightweight setup with very little added extra weight since you are using your drinks as the ice. If you freeze your drinks just right they can be ready to drink at different times during the day.
Keith Pegg   10 mW
Post by Keith Pegg » Jun 21 2018 11:30am
My 3 year old 29r is doing well, I average about 1500 miles a year, try to get in 8 to 10 miles per ride. My coffee holder works very well and the cup seals enough for beach rides or the road, I have a small day head and tail light, I don't ride at night. My trunk is small and slides off easy for shopping. Made out of a collapsible cooler.
Thank you, Keith
June 18 18b.jpg (153.95 KiB) Viewed 567 times
cJune 18 18c.jpg (142.9 KiB) Viewed 567 times
wturber   100 kW
Post by wturber » Jun 21 2018 11:44am
If I were doing extended trips, I'd pack ice cubes into wide mouth stainless vacuum bottles. I'd look into adapting water bottle cages to hold that kind of bottle or something similar. I've done the frozen bottle thing and it is only marginally effective (a few hours) in Phoenix summer heat. I'd expect eight hours or more from the vacuum bottles. The negative would be that the bottles won't hold as much for a given size.
amberwolf   100 GW
Post by amberwolf » Jun 21 2018 12:09pm
FWIW, I have a 64oz "swig savvy" (also sold under other names I forget) SS vacuum bottle that using 10 regular ice-tray icecubes out of the deepfreezer, will still have ice in it (and very cold water or whatever liquid) in it 10-12 hours later, when it's in my SB Cruiser's wooden seatbox cargo area, or CrazyBike2's metal cargoboxes (all of which have 1" of styrofoam insulation inside), even when parked/ridden in the direct sun here in Phoenix.
If it's left in the sun itself, the bottle will still have cold (but not ice-cold) drink, though no ice, in that same amount of time. Unfortunately it only comes in "basic black" for the bottle and it's outer carrying/gripping jacket and plastic lid; I suspect if it were a different color it would stay cold in direct sun somewhat longer.
It also keeps hot things hot, though not as long as it keeps cold things cold. Not sure why. (maybe our perceptions of what is cold and what is hot have different ranges?)
wturber   100 kW
Post by wturber » Jun 21 2018 2:46pm
amberwolf wrote:
Jun 21 2018 12:09pm
I'm guessing its the whole change of state thing. It take a lot of heat to change water from ice to liquid. The heat goes there first and only after the ice is liquefied does the now liquid water actually begin to warm past 32 deg F. Hot liquids don't have that change of state factor working in their favor. They start liquid and end up liquid. The best they can do is take advantage of a wider temperature differential. For instance if you start with super-hot 185 deg F liquid, it can cool 65 degrees and still seem moderately hot. But if you start with cold water, no ice at just above freezing. - 32 deg F - when it warms just 40 degrees, then it is no longer "cold."
But these stainless steel vacuum bottles are great for keeping beverages cold in Phoenix. I love 'em.
markz   100 GW
Post by markz » Jun 21 2018 6:10pm
OK so maybe a well insulated lunch cooler along with those blue freezer things, plus a refridgeration unit attached.
Much cheaper.
DC 12V Thermoelectric Peltier Cooler
https://www.amazon.ca/Thermoelectric-Re ... B079QWMCW3
