djbrandonr
- Joined
- Jan 15, 2018
- Messages
- 31
basically new 10s6p 30Q 40amp BMS or you could bypass...
long story short... I started my E journey with an eboard first then got the idea to build an ebike to do deliveries in manhattan as a side job. So def not a performance bike but as stated a delivery bike. Now before I knew anything about batteries everyone on the board forum raved about the 30Q based on output and capacity and I dont disagree but had i know about the PF cell then, and its reasonable cost to capacity..and only needing 30-40amps max for my budget build I would have bought them first AND am using them now with same range and performance.
That being said... i initially bought a V1 vruzend kit going the full DIY route... but i got shit range out of it and tried trouble shooting the issue here.... needless to say I got tired of poking and prodding that i just bit the bullet and had a reputable battery builder in NYC spot weld everything to put speculation to rest. Amazingly after that the expected range from a 30Q was unlocked and I was on my way (which PFs were already in the mail anyways from nkon). So i assume it was a resistance issue on the vruzend kit and the PFs arrived shortly after to which i built another brick.
So with that said... im interested in letting this go Im just not sure how to price it... nor if it will be worth it...or if i should just rip it apart for another future eboard pack.
would love to hear what you pricing thoughts are... practically new as mentioned once again.
thanks
thanks
