This is probably going to be one of the dumbest questions posted on endless sphere today. If you are using a mid drive motor in your E bike, when you change your gearing while you are moving along, does that change the gear ratio going to the mid drive motor? I’ve built several rear hub E bikes. I’ve also built a scooter and a go cart with a direct drive brushless motor. To change the gearing ratio on those I would need to take off the chain and swap out either the motor sprocket or the wheel sprocket in order to get more torque or more top speed. I’m learning about mid drive motors and want to try that in my mongoose dolomite fat tire bike that I recently bought. I don’t know much about mid drive motors hence the crazy noob question. I’m most likely going to be using lunar cycles 72 V 7500 W mid drive motor. I have no need or desire to use PAS or pedal assist. This is strictly going to be throttle only, no peddling at all. So I’m assuming when I change the gears on my derailleur to go from gear 1 to gear 7 this will change my gear ratio on my mid drive motor and give me more torque or more top speed. Is that correct? Also would it be safe to assume that you wouldn’t have to necessarily change gears at all and just leave it in the 1 or 7 gear? Thanks for any advice.
