So I started with a donor bike and have most of the parts I need to convert but have made some mistakes (as you do when your a newb) and I'm thinking a need to get a new bike.
The biggest issue is that the bike I have has V brakes but the hub and rim kit I got only accepts discs. Instead of wasting time and money trying to adapt a disc to the frame I have I think it will be easier and better to get a new bike that compatible.
My requirements are as follows.
Mountain or hybrid (for commuting mainly)
700c wheel size (29er)
Mechanical disc brakes (easier to convert to ebrakes I already have e-leavers from the kit and cable sensors if needed)
21 speed drive (my hub motor has a 7 speed cassette)
Large size frame (I'm about 6'2)
Everything else is a minor consideration I think in terms of getting the bike going and being safe.
So far I have shortlisted the following bikes available locally to me that fit the bill.
Norco XFR 5 Hybrid 2018
SCOTT ASPECT 970 2018
Trek Marlin 4 2018
Apollo Xpert 10 2017/2018
From what I can tell there isn't much difference between these apart from aesthetics, except maybe the Norco with its more street oritnatated design. All entry entry level running gear bolted to an entry level frame.
Does one stand out as better? Am I missing anything? :?
Cheers!
Trek Marlin 4 2018
Cheers!
