Propofolboy
Hi there! First time poster so hopefully I don't get flamed...
I just built my first E-bike. I had an all steel frame Raleigh Pardner and put on a 1000W 48 V direct drive motor on front hub (CNE bikes, Chinese motor - 48V battery bought from Grin in Vancouver). I had it all working well. I then tried to clean up the cables...
I went to ride it this morning and the throttle lights showed a full battery but when I applied throttle there was no output from motor. I assumed the connection was not tight, so replugged it in and out.. nothing. Then I undid a couple of my cable ties on the front fork, and gave some slack where the wires come out of the axel on the motor. This solved the problem. The axel wires have a wire coil covering for protection, and assumed that this prevent kinking.. but obviously the way I had it tied down prevented it from working...
Should I be concerned that there is a loose connection somewhere, or just allow a little more slack on these wires and not worry about it. Any tricks or tips to securing it without causing this to happen?
Thanks!
Thanks!
