SpongeRob1976
- Joined
- Mar 28, 2017
- Messages
- 4
I converted my 2016 Specialized Crosstrail Expert bike to an ebike a year and a half ago. I have both a PAS and a thumb throttle. The thumb throttle is just a back up since I have had issues off and on with the PAS over my time riding the bike. I love the PAS and prefer to use it that way but here are my issues...
I have a dual chain ring setup on the front and more than a few times my chain has skipped off on the inside and one of the following has occurred...
1. chain slides down between the PAS ring and the sensor on the downtube pushing it back so it no longer senses the PAS ring magnets. Fairly easy to fix.
2. chain slide down and gets between the PAS ring and the small chain ring, less common but has happened, which causes the PAS ring to break off. Lost one half of the PAS ring once. The second time I did manage to recover both pieces. This most recent time I still recovered it but additional issues need to now be sorted out.
In mounting my PAS ring, I wasn't able to get it to stay put using just the magnets. I did change my chain ring bolts to steel but it always wants to shift and I go over some bumpy areas on my commute so I didn't think it would be sufficient to do it that way. In the end, after doing a bit of searching online, I decided to use some JBWeld and glued the PAS ring to my chain ring bolts. That worked fairly well after my second attempt at gluing it and has been working for over a year. The downside is that I recently mangled my small chain ring and need to replace it. Since I glued it in place, it was a pain to get it cleaned up enough to get the bolts out to remove my chain ring.
I am wondering if anyone has figured out a better way to mount a PAS on a hollowtech style crank set? I would really like to do the PAS on the left side but there is no way to make it work from what I can tell. I would prefer not to have to glue it again if I can avoid it. What are you all doing to get it mounted securely?
Thanks,
Rob
Thanks,
Rob
