Can I use one controller on 2 motors or do I need 2 controllers... I have front motor laced and mounted and a whole mess of wires .. please someone help!!
people generally use two controllers. If you wire your throttle properly you can use one throttle. However, getting the motors to run in a somewhat synchronous manner is tricky as one motor usually wants to go faster then the other.
