Hi everyone, I am having trouble with a converted e-bike, and I thought someone here might be able to help me out.
The set up:
The kit was bought from Leoncycles and has LG Das-kit written on the Display which goes on the dash.
Motor: Bafang 250 W 36V, BFSWX02
Magnetic peddle sensor plus controller.
I did not connect the trottle or break sensors.
Controller has a 30V low voltage cut off.
The display shows the speed, which it must get from the motor revolutions. From the display you can select the amount of assist with six different levels.
Problem:
The bike no longer gives full power, unless the speed is very low, around or less 8 km/h.
The display also does not always show the right speed. Often it shows 0, but this doesn't affect the amount of power. The power seems seems to still be determined by the actual speed. his problem with the speed display started long before I had any issues with power, so I just ignored it.
Edit:
I put a very similiar set up on two bikes. So I was able to use the second bike to trouble shoot the first. By connecting different parts of both bikes together I narrowed down two issues.
1. The speed measurement which is often wrong is from of the control box, or one of it's connections.
2. The low power loss at lower speed than usual, is from the motor, or possibly the connection to the motor.
Some more info:
The kit was very easy to fit, and worked great for over 1500 km or so. Then I had a problem where it would cut out over pumps, which I guessed was due to a bad connection to the battery. The connectors from the controller didn't fit well to those on the battery. So i got rid of them and solder the wires instead. This fixed the cutting out problem, but now I have the low power problem. Could it still be a problem with connection to the battery?
I put the bike under load and wobbled all of the main connections, none of the seemed to have an effect. Could it be the motor itself. I think those are usually very reliable so I reluctant to take it off and open it up.
One other point. In the display you can choose a wheel size. I have 28 " wheels, but I set them to 20 ", as this seemed like a simple way to turbo charge it. Then it assisted a little at around 30 km/h max which was great.
Thanks in advance for any advice.
The set up:
Problem:
Edit:
Some more info:
