markz
100 TW
How does one calculate using two normal IGH with a gear mounted on the spoke flange for both IGH?
Crank of 10T going to the regular #1 IGH Gear of 20T
3 Speed IGH internal ratio's are both 75/100/125%
A 30T flange mounted gear going to the normal #2 IGH Gear of 40T with same ratios, and a 50T flange gear.
Going to a 60T cassette on the back 26" wheel.
Both set to 75%
What I do not understand is the crank gear of 10T is going to 1st IGH, with its "normal" operating gear of 20T and the IGH set to 75%, but then there is an added gear mounted on the flange. Different then the common Compound Gearing thats easily solvable.
How does one finish the calculation?
Simpler gearing situations.
With just one IGH
(Out/In)*IGH % Ratio
IGH Gear of 20 / Crank Gear of 10
= 20/10 is 2
multiply
IGH % of 75% = 1.50 on a 26" wheel.
IGH internals 75/100/125%
IGH % of 125% = 20/10=2*1.25(125%) is 2.50
1.50 vs 2.50
IGH at 75% is a 2.50 which is more torque and less speed for same cadence
75% is a 1.50; more speed and less torque for same cadence.
Normal Bicycle
22T Crank and 44T Cassette 44T/22T = 2 for Hills
44T Crank and 10T Cassette 10T/44T = 0.23 for Speed
Both set to 75%
With just one IGH
= 20/10 is 2
multiply
1.50 vs 2.50
Normal Bicycle
