onetearless
- Joined
- Aug 20, 2017
- Messages
- 14
I got a very inexpensive frame to practice building an ebike for the first time. I had difficulty utilizing the bottle cage brazeons in the main triangle. Instead I went for attaching the pack under the down tube for lowest center of gravity (had to drill holes in the frame to do so). I did this with out accounting for fork travel. It is probably ok but not perfect. I want to ask the opinion of the group. Switch to non suspension fork and give up whatever benefits I might get from the worn and cheap suspension or relocate the battery to the MAIN triangle and have 4 small holes under the downtube?????? Please and Thank YOu!!
