onetearless
- Joined
- Aug 20, 2017
- Messages
- 14
I bolted the mounting plate to the bottle cage mounts and attached it directly to the frame at the farthest point with out putting screws in between. I think I managed to create just enough flex in the mounting plate to keep the pack from seating fully (2-3 mm off). So frustrating!!!!!
The bike powers up and works well but I can't lock the battery to the mounting plate. It feels solid and doesn't seem to be a problem. Do I need to pry mounting plate up from the frame again and remount with shimming and new adhesive or should I just ride it until there is a problem.......... :wink: :wink:
