Talon
I have a small Pro-GT URB-E. I want to buy a CA-DP for measurements being taken out of my battery while riding. I just read the online manual on the CA-DP. I have a PowerVeloCity 6FET Bluetooth programmable controller already hooked up that has a CA plug on it. My question is in the setup menu it shows that a 16"wheel is the smallest wheel setup in the manual. My aftermarket rear hubmotor tire is 10" in diameter and the tire circumference is only 864mm big. Can someone tell me if the setup menu will adjust down to my 10" wheel with a 864mm so I could get an accurate speed, and odometer reading? I do have hall sensors inside of the hubmotor. I will not order a CA if not. Thanks
