Where i ride, i intermittently have to go bicycle speeds, and car traffic speeds. It's difficult because there is no such thing as one tune that works best for both. I don't know of any modern controller that has multiple programmable tunes that you can switch on the fly with a physical button. So i'm thinking about running two controllers.
Also, when going fast, i believe in the old adage that loud pipes save lives. I want motor to scream when you throw thousands of watts into it, but be completely silent when cruising along a bike path with pedestrians or other cyclists.
So here's the idea.
Hook something like an 18FET infineon/xie chang clone and 6FET FOC controller like a phaserunner in parallel to the motor.
The 6FET FOC gets tuned so that it only produces a top speed of 20mph and has much weaker acceleration.
The 18FET xie chang is tuned for 'balls to the wall', but still has a 3 speed switch so that you can very between 30, 40, 45mph.
There is one throttle, and the ground/negative is paralleled between both controllers, but the other two wires are switched between the little 6FET and the big 18FET using a double pole switch.
Are there any possible holes in this plan? I wonder if 5000w peak flowing through the phase wires may leak some current back into the smaller controller and make it go kaboom.
So here's the idea.
