Hi,
I commute regularly following 5.5miles long route through the forest to the train station :
As you can see it's daily almost 2 hours of healthy MTB training (mostly gravel road not suitable for city bikes). I would like to reduce time spent on the route (forth and back) under 50 minutes (as I have kids now :wink: ). That means I need at least double my average speed to at least ~15 miles per hour (25km/h).
From what I read here I really like TSDZ2 central motor with torque sensor but there are opinions that central motors are not so reliable in the long run. Rear hub motor could have problems in more steep sections is that right ? On the way back there's 3.5mile long section with ~7% average gradient (one short section just 0.2miles with 13% gradient). My weight is 210pounds (95kg) and I would like use motor on my 29" MTB (steel frame). What motor would you recommend ?
I think I don't really need strong motor 250w-350w should be enough for my needs as I will be pedalling as I am used to. Also legal limit of motor assistance is <=15miles per hour in my country and only <1kw motors.
