Mac 10 rear vs front overheating
1boris   10 W
Post by 1boris » Feb 09 2019 4:12pm
Since the new front mac motor has a heat bridge from the stator to the outside will it take significally more time to overheat a front mac motor than a rear casette version?
amberwolf   100 GW
Re: Mac 10 rear vs front overheating
Post by amberwolf » Feb 09 2019 11:30pm
What heat bridge?
What is the heat bridge's thermal resistance numbers? YOu can use that to calculate how much heat will move out how quickly, which will then let you compare to a motor without that heatbridge (assuming all else is equal).
neptronix   100 GW
Post by neptronix » Feb 10 2019 12:39pm
Yeah what heat bridge? i've never heard of such a thing.
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
1boris   10 W
Post by 1boris » Feb 10 2019 4:36pm
You see the heat bridge in the link below.it goes from stator and through the side cover to the outside of the motor.
https://endless-sphere.com/forums/viewtopic.php?t=86939
1boris   10 W
Post by 1boris » Feb 11 2019 12:58pm
amberwolf   100 GW
Post by amberwolf » Feb 11 2019 10:59pm
Assuming the part you're talking about is the bit with five bolt holes in it, I suppose if you bolt a big finned plate to that, it might help transfer heat out of the motor, depending on how it's connected to stuff inside (can't really see that part clearly).
