Page 1 of 1
Mac 10 rear vs front overheating
Posted: Feb 09 2019 4:12pm
by 1boris
Since the new front mac motor has a heat bridge from the stator to the outside will it take significally more time to overheat a front mac motor than a rear casette version?
Re: Mac 10 rear vs front overheating
Posted: Feb 09 2019 11:30pm
by amberwolf
What heat bridge?
What is the heat bridge's thermal resistance numbers? YOu can use that to calculate how much heat will move out how quickly, which will then let you compare to a motor without that heatbridge (assuming all else is equal).
Posted: Feb 10 2019 12:39pm
by neptronix
Yeah what heat bridge? i've never heard of such a thing.
Posted: Feb 10 2019 4:36pm
by 1boris
You see the heat bridge in the link below.it goes from stator and through the side cover to the outside of the motor.
https://endless-sphere.com/forums/viewtopic.php?t=86939
Posted: Feb 11 2019 12:58pm
by 1boris
Posted: Feb 11 2019 10:59pm
by amberwolf
Assuming the part you're talking about is the bit with five bolt holes in it, I suppose if you bolt a big finned plate to that, it might help transfer heat out of the motor, depending on how it's connected to stuff inside (can't really see that part clearly).
