BionX
Stilo77   1 mW
Re: BionX
Post by Stilo77 » Apr 13 2019 10:36am
Thank You!
Stilo77   1 mW
Re: BionX
Post by Stilo77 » Apr 15 2019 11:53am
Cephalotus wrote:
Apr 13 2019 4:57am
If you have a BionX DS3 display the latest official version is 4.0
The BionX DS3 display has another plugin than G2 display and BionX interface box.So you can't connect this interface with DS3 display?Thanks
DS3 display.jpg (3.4 KiB) Viewed 629 times
G2 display.jpg (5.29 KiB) Viewed 629 times
My interface.jpg (5.36 KiB) Viewed 629 times
Cephalotus   10 kW
Re: BionX
Post by Cephalotus » Apr 17 2019 12:22am
RC3+DS3 and G2 are not compatible. You also need deifferent firmware versions in the motor for each.
For 48V batteries you can use the hybrid version 115 on both. Batteries with lower nominal voltage than 48V are not compatible with RC3+DS3
Stilo77   1 mW
Re: BionX
Post by Stilo77 » Apr 17 2019 12:57am
I understand.The RC3+DS3 has compatible bionx interface?My interface is this one:
My interface.jpg (5.36 KiB) Viewed 605 times
Cephalotus   10 kW
Re: BionX
Post by Cephalotus » Apr 17 2019 2:33am
Stilo77 wrote:
Apr 17 2019 12:57am
Yes, your BIB2 is compatible to any BionX component
Stilo77   1 mW
Re: BionX
Post by Stilo77 » Apr 17 2019 12:08pm
Cephalotus wrote" Yes, your BIB2 is compatible to any BionX component"
But is not good the BIB2 s plugin with DS3 plugin.
DS3 display.jpg (3.4 KiB) Viewed 587 times
My interface.jpg (5.36 KiB) Viewed 587 times
Stilo77   1 mW
Re: BionX
Post by Stilo77 » Apr 17 2019 1:31pm
I dont have DS3 display, only I have G1 and G2 displays.I don't know how the DS3 display end his plugins looks like in reality. :?
Cephalotus   10 kW
Re: BionX
Post by Cephalotus » Apr 17 2019 5:09pm
DS3 connects via 4 pin connector to the RC3.
RC3 uses the (for BionX) typical Hirose30 connectors for its CAN bus system. So you connect DS3 via RC3 to the BIB2.
Couldn't find a picture online so I made you one:
Cable to the left is for braking sensor.
Stilo77   1 mW
Re: BionX
Post by Stilo77 » Apr 19 2019 9:00am
Cephalotus wrote:
Apr 17 2019 5:09pm
Thank you very much!
pvn1012   1 µW
Re: BionX
Post by pvn1012 » Apr 24 2019 8:30am
When downloading the bbi software from this link: https://www.file-upload.net/download-13 ... e.zip.html to my mac I did get a message from AVG that the download was infected by a virus (see picture).
Can you attach send me the software by an other way? Can you attach this to the thread? Or send it with wetransfer.com to my email account or ???
Thanks!!!
Cephalotus   10 kW
Re: BionX
Post by Cephalotus » Apr 28 2019 5:51am
It's a self extracting file, maybe this is the reason why it is blocked.
I can not comment on the file hoster. I have no experience with those
Stilo   100 µW
100 µW
Re: BionX
Post by Stilo » May 01 2019 6:11am
Cephalotus wrote:
Apr 13 2019 5:50am
As far as I know BionX software wants to update 30 days after installation. This is not possible any more because Bionx servers are down.
Therefor the BionX needs a faked date, based on the installation time hidden in the license file bbi.db.
I can only use it when I set back that date manually and use my PC offline.
I use a bit older license version, so I may date varies from the date you need to use for that version, at least this is what I believed. I assume that you have to set the date for this version to somewhere around November 2018.
Your PC still uses the actual date and the software works?
If so, I don't know why :-)
Hi Cephalotus!
I tried to use the program online and it worked perfect! First updated itself and then it updated the console, motor and battery firmware.
nantucket101   1 µW
Re: BionX
Post by nantucket101 » Jul 31 2019 6:21pm
Hi folks, apologies for the potentially dumb questions. I'm talking to someone who has the USB BiB interface about possibly getting my equipment unlocked. Would the uploaded offline license / debug mode let you unlock the 20mph limit? Or is that not possible without using 3rd party software/3rd party unlock methods? This is for a 2016 P 350 DV (gen 2 display i think)
Thanks!
Update: I eventually figured it out. All you need for a G2 console is the BBi2 software, a bbi cable, debug mode, and this very important parameter:
console.assist.maxSpeedFlag = 0
