PAS using VESC
evbkezzz   1 mW
PAS using VESC
Post by evbkezzz » Aug 02 2019 2:05am
I am trying to build a PAS on my ebike which uses a VESC controller. I stumbled upon two great projects by
viewtopic.php?f=28&t=84042&p=1231237#p1231237
https://www.pedelecforum.de/forum/index ... ler.11188/
Both of them seem to fit my needs but unfortunately I don't understand German. The first project is a fork of the second and works on a Teensy controller and uses a color display.
I feel teensy is a bit expensive. Can I use it on a ESP32? If not, how do I modify it to work on a ESP32 or similar mcu.
The post states the battery capacity,voltage, speed,etc are taken from VESC, does the VESC read battery capacity, voltage, etc?
Thanks
Andy!
