Pegazus 100 mW
Post
by Pegazus » Sep 17 2019 3:45am
Hi,
I have a nice Kunteng controller but I'm struggling with the pedal assist.
I first bought a KT-V12L but as described by many people the feeling is not really good.
https://fr.aliexpress.com/item/32866352633.html
I would like to move on a real torque sensor like the sempu T4.
https://fr.aliexpress.com/item/32952233498.html
Could anyone tell my what are the compatible torque sensors that could work with the KT controller ? I'm interested in references even if it is not plug and play.
Thanks
stancecoke 100 kW
Post
by stancecoke » Sep 17 2019 6:57am
I recommend the e-rider sensor
https://www.aliexpress.com/item/3303013 ... b201603_53
The working principle and pinout is the same as the Sempu T4, but the geometry of the turning shaft is better, no groove for the circlip.
It works perfectly with our open source firmware for the Kuntengs, see my signature.
regards
stancecoke
stancecoke on Sep 17 2019 9:10am, edited 1 time in total.
Pegazus 100 mW
Post
by Pegazus » Sep 17 2019 7:17am
I don't understand the wiring.
On my KT controller input I have :
- 1 red wire : +5V
- 1 black wire : GND
- 1 white wire : PAS signal
On the other side, on the e-rider or sempu, I have 4 wires :
- 1 red wire : +8-12V
- 1 white wire : torque signal
- 1 green wire : speed signal
The is 1 wire in excess and the required voltage power which is too high.
How is it possible to manage that ?
stancecoke 100 kW
Post
by stancecoke » Sep 17 2019 7:32am
36v --> DC/DC step down --> 12V --> red wire (supply)
gnd --> black wire (gnd)
PAS signal --> green wire (speed)
throttle signal --> white wire (torque)
If you want to use a throttle in parallel, you have to use pad X4.
regards
stancecoke
Pegazus 100 mW
Post
by Pegazus » Sep 17 2019 7:43am
It definitely make more sense using the throttle signal wire !
But what is a pad x4 ?
john61ct 100 GW
Post
by john61ct » Sep 17 2019 8:26am
How does the above option compare to using CAv3 ?
Setting cost aside, assuming you already plan to buy one for other features?
stancecoke 100 kW
Post
by stancecoke » Sep 17 2019 9:07am
Pegazus wrote: ↑Sep 17 2019 7:43am
That's a solder pad on the pcb for an additional analogue input.
john61ct wrote: ↑Sep 17 2019 8:26am
Pros:
--> No additional hardware (and no quite ugly display
--> completly free configurable
--> bluetooth + cellphone app available
Cons:
--> just a hobby project, no professional support
regards
stancecoke
Powerhour 100 mW
Post
by Powerhour » Sep 22 2019 2:38pm
The fact this eliminates the need for a ca3 kicks so much ass
john61ct 100 GW
Post
by john61ct » Sep 22 2019 3:36pm
Except with the CAv3, the torque sensing PAS is just one feature out of dozens, in fact one that's probably use much les frequently than the others.
Pegazus 100 mW
Post
by Pegazus » Sep 23 2019 2:25am
Thank you very much for the explanation !
Powerhour 100 mW
Post
by Powerhour » Sep 23 2019 4:38pm
john61ct wrote: ↑Sep 22 2019 3:36pm
This is actually one of the CA3's main selling points, because it has a wide range of presets for torque sensors along with the ability to configure any sensor with any controller, and I don't think there's really many other options out there for that besides this firmware. Other than that the CA3 is a throttle hacker and output monitor on a dot matrix screen. With this firmware, I can see that I can also edit the gains and ramps etc as well. Plus a graphic interface for monitoring, including phase patterns, back emf etc? Pretty kickass stancecoke nice work I'm stoked about it
Phil42a 1 µW
Post
by Phil42a » Oct 26 2020 6:37am
Hi,
I bought a sempu torque sensor (latest version supporting up To 60V supply) that I intend to power directly from the 36V battery. The sensor is also providing the PAS speed info with 48 pulses per round as compared to 10 for my classical PAS sensor. I have connected the Torque signal to the Throttle input through a OR schottky diodes network to make sure the signal is below the Throttle input threshold (which is 1.25V) : I get 1.22 when the sensor is in rest position so no effect. Prior to engage in Controller reflash, I was wondering how the controller would react in this configuration with the original Firmware. Would it work , and if so what would be the best parameter setting for the KT controller ?
