TSDZ2 open source firmware only for KT-LCD3 (v0.19.0 / v.0.20.0beta1)
jeff.page.rides   100 W
Re: TSDZ2 open source firmware only for KT-LCD3 (v0.19.0 / v.0.20.0beta1)
Post by jeff.page.rides » Mar 18 2020 1:12pm
Rydon wrote:
Mar 17 2020 1:18pm
mbrusa wrote:
Mar 17 2020 9:35am
The HEX file is for the TSDZ2 controller, only that has changed.
For LCD3, the buba 20 beta 1 version is still fine.
Ok, got it. Having LCD3 in the title of the hex file made us think it was for the KT-LCD3. We will try it in the motor today. Thanks!
It flashed fine, everything seems good I'll give it a try on Friday when the rain stops.
Post by jeff.page.rides » Mar 18 2020 6:11pm
jeff.page.rides wrote:
Mar 18 2020 1:12pm
Rydon wrote:
Mar 17 2020 1:18pm
mbrusa wrote:
Mar 17 2020 9:35am
The rain stopped today and the clouds parted so I went for a ride. The overrun fix works, but I still have to give a quick yank back on the pedals to get the hub to shift when there's pressure on the chain.
mbrusa   10 W
Post by mbrusa » Mar 19 2020 2:53am
Mar 18 2020 6:11pm
I do not understand. Can you explain better?
Flexible OpenSource firmware for TongSheng TSDZ2 motor and VLCD5 VLCD6 XH18 displays
https://github.com/emmebrusa/TSDZ2-Smart-EBike-1
stancecoke   100 kW
Post by stancecoke » Mar 19 2020 3:45am
Mar 18 2020 6:11pm
I think he uses an internal-gear hub. You can't change the gear with tension on the chain. So you have to unload the chain by turning the pedal backwards slightly.
regards
stancecoke
mbrusa   10 W
Post by mbrusa » Mar 19 2020 6:01am
Of course, with the gear on the hub, also with "fix overrun" the chain always remains under tension if the pedals are not released.
Post by jeff.page.rides » Mar 19 2020 11:05am
stancecoke wrote:
Mar 19 2020 3:45am
Mar 18 2020 6:11pm
regards
stancecoke
Sorry, I do use a Nexus or Alfine hub.
I think the next step I want to try is a gear shift sensor hooked up to either the brake cut off or like in this post on the other forum the Speedo sensor.
viewtopic.php?f=30&t=98281&start=825#p1533489
If the shift sensor is hooked up to the brake sensor it may stop power for too long?
If the shift sensor is hooked up to the speedometer sensor it may or may not work?
What would you suggest I try next?
Here are some YouTube links about my bike,
viewtopic.php?f=28&t=79788&start=6775#p1537314
Thanks
maximusdm   10 W
Post by maximusdm » Mar 20 2020 6:14am
I have created a pull request on Buba's repository so this important fix does not get lost.
mbrusa   10 W
Post by mbrusa » Mar 20 2020 10:06am
Mar 19 2020 11:05am
Thanks
I don't know the gearsensor but it is certainly better to connect it to the brake sensor, the response time is immediate and the duration of time does not depend on the software but on the time of the signal of the gearsensor, which I believe is already optimized for that.
It will always be necessary to stop pedaling but it will be easier to synchronize the engine stop with the gear change.
Waynemarlow   1 kW
Post by Waynemarlow » Mar 21 2020 8:43am
Guys,
Finally I've got the new controllers arrived from China ( ordered early Jan ) after drowning my motor ( it had a very early sealing system on the chain side ) and will need to reprogram them. Do we have a single motor file with the new over run solution available suitable for the LCD3 ( Buba Beta 20 + over run changes ) and also I'm presuming we do not need to reflash the LCD3 screen file ?
Still liking the LCD3 which just works so well in daylight.
Thanks
maximusdm   10 W
Post by maximusdm » Mar 23 2020 10:10am
Hello,
Here is the pull request I did starting from Buba's code. It has the overrun fix and an additional fix for torque sensor with minimal value smaller than 100 so it does not give torque sensor error.
https://github.com/leon927/TSDZ2-Smart-EBike/pull/2
You can build your binaries from my development branch.
Regards!
thineight   100 W
Post by thineight » Mar 29 2020 10:28am
Hello guys. In these days of quarantine I had chance to flash the v.20 with mbrusa overrun fix.
The overrun is of course improved with good results, but I experienced a delay in motor kick in while restarting pedaling.
I have to do at least a complete pedal turn prior the motor engages.
Did anyone else experience the same?
I wait some feedback.. in case I will try to go back to the previous buba "official" beta1.
Thanks
MTB KTM Ultra 29" - City bike DAYTONA 28"
mbrusa   10 W
Post by mbrusa » Mar 29 2020 2:09pm
mbrusa wrote:
Mar 21 2020 2:11am
I want to highlight that by increasing the calculated value of "ui16_cadence_sensor_ticks_stop", increases the overrun time, decreasing it lacks startup assistance.
I had reports of too fast stops and a case of lack startup assistance.
For this reason, in the next full version I will slightly increase the calculated values.
"ui16_cadence_sensor_ticks_stop = (ui16_cadence_sensor_ticks + (ui16_cadence_sensor_ticks >> 3)));" in standard mode,
"ui16_cadence_sensor_ticks_stop = (ui16_cadence_sensor_ticks + (ui16_cadence_sensor_ticks >> 1));" in advanced mode,
or maybe I'll add editable parameters in the config.h file.
Hi thineight
I had reported it in a previous post.
Post by jeff.page.rides » Mar 30 2020 7:45pm
mbrusa wrote:
Mar 20 2020 10:06am
Mar 19 2020 11:05am
Thanks
I installed my shift sensor on the brake sensor plug and wow does it shift great. The second I push my shift button the motor stops it shifts fast, smooth, and quiet. Now the problem is it powers off for about 2 seconds and about 2 revolutions at 75 RPM before the power comes back on, that's a long dead-spot.
Is there a way in the firmware that we can speed up this power back on, to only a half a second?
mbrusa   10 W
Post by mbrusa » Mar 31 2020 7:33am
Mar 30 2020 7:45pm
I should understand if it depends on the "fix overrun" or anything else.
If you are using the version with LCD3 can you try this modification?
It slightly increases the overrun time and decreases the restart time.
If it improves, it is possible to further change the relationship between overrun and restart.
TSDZ2-v0.20.1-fix_overrun_test-LCD3_version.zip
(42.94 KiB) Downloaded 55 times
Post by jeff.page.rides » Mar 31 2020 11:41am
mbrusa wrote:
Mar 31 2020 7:33am
Mar 30 2020 7:45pm
If it improves, it is possible to further change the relationship between overrun and restarts.
I am using the LCD3 with version 20 beta 1 and the overrun fix installed a couple of weeks ago. Is this file the same or is it something you've changed for me to try?
mbrusa   10 W
Post by mbrusa » Mar 31 2020 1:30pm
Mar 31 2020 11:41am
Yes it is a new version to try.
Post by jeff.page.rides » Mar 31 2020 5:58pm
mbrusa wrote:
Mar 31 2020 1:30pm
Mar 31 2020 11:41am
Thanks, I'll give it a try on Friday. Do we need to just flash the TSDZ2 I hope or do we have to flash the LCD3 also?
mbrusa   10 W
Post by mbrusa » Mar 31 2020 10:48pm
Mar 31 2020 5:58pm
Only the TSDZ2.
Post by jeff.page.rides » Apr 03 2020 7:54pm
mbrusa wrote:
Mar 31 2020 7:33am
Mar 30 2020 7:45pm
I rode 25 miles today on my handcycle and I didn't notice any difference with the changes that you made.
It all seem to be exactly as before.
THANKS
mbrusa   10 W
Post by mbrusa » Apr 04 2020 12:51am
Apr 03 2020 7:54pm
THANKS
Positive is that it does not depend on "fix overrun".
I think I understand where the problem is.
The stop with the brake sensors is immediate, but the restart of the engine is not.
This is because the restart code is in ebike_app.c which has a delay in execution of 0.1-0.2 seconds.
I can modify it but I don't have LCD3 and not even brake sensors to try.
Do you have only gear sensor or also brake sensors?
Are you available to try the change even if not tested?
Waynemarlow   1 kW
Post by Waynemarlow » Apr 04 2020 7:01am
Mbrusa
Do you have a link to the hex file for the motor based on your changes and Buba's V20, I'm just about to reprogram a unit and refit it to the bike
Thanks
Post by jeff.page.rides » Apr 04 2020 10:49am
mbrusa wrote:
Apr 04 2020 12:51am
Apr 03 2020 7:54pm
THANKS
I have the gear sensor hooked up where the brake sensor goes and that's it no brake sensor is used. Yes, I will test a new firmware change even if it hasn't been tested by you. THANKS
mbrusa   10 W
Post by mbrusa » Apr 04 2020 1:33pm
Apr 04 2020 10:49am
Okay let's do this test.
I send you the hex file with a private message, then if it works I will released it on the forum.
mbrusa   10 W
Post by mbrusa » Apr 04 2020 10:22pm
Waynemarlow wrote:
Apr 04 2020 7:01am
Mbrusa
Thanks
The last hex file for the motor, version with LCD3 display, can be found on this page a few posts back.
download/file.php?id=269437
Post by jeff.page.rides » Apr 05 2020 11:01am
mbrusa wrote:
Apr 04 2020 1:33pm
Apr 04 2020 10:49am
I didn't notice any difference in the start-up time after I shift still at 2 seconds or 2 revolution.
I think the perfect setup would be that when you shift the motor stops completely like it does and then within a half a second it starts ramping up power and by the time you hit 1-2 seconds it's at full power again.
It could be me but it seems like with these last couple of hex files I have to shift early because power levels off at 70 RPMs and by the time you hit 80 it has half the power and by 90 it's almost zero.
Thanks for all your efforts!
