So hi guys,
I have just finished my ebike with a Cyclone 3000W kit and a 52V 24ah GA battery from LunaCycle. I hooked up a bluetooth controller (Rated for 3000W) from YuYangKing.
When I drove (battery 90% charged) the motor stopped turning, it just shut off. But the rest of system was still powered^^
I have a 13T sprocket on the motor, 44/44T in the middle and im in 3rd or 4th gear on a 9 x cassette.
I built my own chain tensioner, but it isn't that tight.
Could it be the phase wires, I had to change green and blue wires (green from controller to blue from motor) because the motor was stuck. But I haven't found a way to run it otherwise. (It0s either reverse or stuck)
I have realised, that the motor is slightly skew, but really not much. Could this be the issue? The mounting from lunacycle is straight.
Thanks for all your help!
