My1018 brushless alternative?
HrKlev   100 W
Post by HrKlev » Jul 19 2020 4:32pm
Im looking at making a diy torque sensor, low power (5-700w peak), light weight mid drive. I currently have a tsdz2 which I like very much, except the ground clearance. I do have a MY1018 brushed motor laying around here, a BB torque with a freewheel on the way, and a CA v3. Trying to make a lightweight system I will also use a small battery as possible for what I need, and I am a little sceptical about how efficient the brushed MY1018 motor is. Last time I used it I only had a cadence based system, so its not a direct comparison, but it used almost twice the energy as the tsdz2 on the same routes. The MY1018 ticks all the other boxes with size, gearing and power. I have tried finding a comparable brushless motor, but cant seem to find anything. They are either way too big (cyclone, etc), or small without reduction gears (RC motors), and thus way too high rpm. Are there any brushless motors in the 500-1000w area with planetary gears that would be suitable for a mid drive build?
DIY lightweight mid drive with torque sensing build thread: viewtopic.php?f=6&t=107622
amberwolf   100 GW
Re: My1018 brushless alternative?
Post by amberwolf » Jul 19 2020 5:28pm
HrKlev wrote:
Jul 19 2020 4:32pm
Which kind is it? There are several types, some with gears, some with mounts welded to the casing, different types of casing, etc. Depends on which kind it is as to what could be used to replace it.
Brushed motors are less efficient than brushless, but not necessarily by all that much. The main thing is relative to your particular usage and setup, whetehr the motor is wound for the speed you want out of it under the load you are putting on it. That's true of either motor type.
So you would want to first decide the speed you want out of the motor, under it's load. Typically something like 80% of it's unloaded RPM is going to be it's max loaded RPM. If you need to use it at high loads at a lower speed, you'd want to gear the system to work at those speeds, or have shiftable gears that are setup for the speed range(s) you need.
FWIW, geared hubmotors, which output in the RPM ranges your cranks would see, have been used for this. So have DD hubmotors...but the geared hubs have the option of remachining some parts to turn them into *axle drive* units instead of *housing drive* units, making htem a little easier to use in a middrive in a frame, wihtout putting a cover around the housing so you don't have stuff (or you) rub or catch on it. Crossbreak did it here to at least one motor, and there's other similar threads.
viewtopic.php?f=28&t=45245
HrKlev   100 W
Post by HrKlev » Jul 20 2020 2:12am
amberwolf wrote:
Jul 19 2020 5:28pm
Sorry, I forgot there was several types of this motor. It is a 36V 450w motor with internal reducer gears. It is listed as 450rpm on electric scooter parts, sp I would think that is unloaded. https://electricscooterparts.com/hookup ... X2500B.pdf
Hm, maybe I should give it another go. Its free after all. The motor is going on a bike that is used for quite tecnical single trails, so the rpm will vary a lot. 120rpm cadence for short bursts, but most of the riding will be a lot lower, probably closer to 70-80rpm cadence most of the time. So my plan was to use the 14t freewheel that is already on it, and a 42t chainring. That would give me the 120rpm max cadence I want.
Thanks a lot for that info! I remember reading about it some guys using huge hub motors as mid drives, so I dont know why I didnt think about small hub motors could be an alternative :P I will do some reading!
gogo   10 MW
Post by gogo » Jul 20 2020 4:32pm
The My2018 has heat limitations and will waste lots of electrons once its getting thermally stressed.
"A conclusion is the place where you got tired of thinking." -Steven Wright
HrKlev   100 W
Post by HrKlev » Jul 26 2020 4:41pm
Decided to give the my1018 a go. Cyc torque sensor, freewheel, a chopped up cyclone chainring as an adapter from whatever bcd the freewheel is to 104 bcd chainrings. And some other things I found in the parts bin. Will wire it up with the Cycle Analyst tomorrow and do some testing. If it is decent I will clean it up some more and maybe finally make the casing for the battery :lol:
HrKlev   100 W
Post by HrKlev » Jul 27 2020 10:58am
Did a test run today to compare the efficiency with the tsdz2 I had installed before. It was empty 7 km from home, even if I tried to be economical the last 50% of the ride. Definately a lot thirstier, unfortunately.
So compared to the tsdz2:
Pro's:
-Ground clearance
-Less resistance when battery is empty
-Chainline
Cons
-Not as efficient
-NOISE!! Slightly embarrasing passing people out in the forest on something that sounds like an electric chainsaw :lol:
-Couldnt find a way to tune out the snap I get in the driveline when to motor starts with the CA. At least not with still having the response needed for single trail riding
I think the tsdz2 goes back on for now, and I'll live with the ground clearance. At least until I get my hands on a small hub motor and coverts it to axle drive or something else. At least now I have a spare setup for when the tsdz2 breaks. It was a fun project after all :)
andrea_104kg   100 W
Post by andrea_104kg » Aug 14 2020 5:22pm
Congratulations on experimenting, it has always intrigued me. The noise depends on both the chain and the straight teeth of the motor reducer. I know they have built a version with helical teeth but it is not easy to find. As for the power how is it compared to the tsdz2?
HrKlev   100 W
Post by HrKlev » Aug 15 2020 2:12am
Thanks! Most of the noise was definately the gear reduction growling. I have a cyclone 3kw (running only 600w@35v) on my fatbike now until I receive some other oarts, and its whisper quiet compared to this. Maybe its something wrong with the my1018. I tried to find the one with vertical gears when I bought mine, but no success unfortunately.
I didnt test full power, I just set max 500w input power like my tsdz2 and adjusted the torque setup until they felt about the same. Normally I use about 2-300w assistance on the trails. The my1018 ran out of power long before the tsdz2, so a lot more of that power went to heating, unfortunately. It did seem like I had to use higher assistance level compared to the tsdz2 to keep the same speed on the fireroads in between. Didnt do any accurate testing, though, the noise kind of made me lose some interest :p
geofft   1 kW
Post by geofft » Aug 16 2020 3:18am
HrKlev wrote:
Aug 15 2020 2:12am
I'm fairly sure the MY1018 motor has straight cut reduction gears and are noisy beasts. Check out the XYD-16 version of this motor, this looks identical to the MY1018 but is fitted with helical reduction gears. From what I remember from playing around with these motors a few years back the helical version is much quieter.
BBS02 V2 48v 750w, 12s lipo.
Q128H (36v 201rpm), KT36/48SVPR 6-fet, LCD3, 48v 12s lipo.
HrKlev   100 W
Post by HrKlev » Aug 16 2020 11:13am
Yeah, that was the one I was searching for, but didnt find any places to buy from which seemed like a serious site. Anyway, I have ordered a Bafang g311 and a baserunner, that I will be mounting as a mid drive. Seems like Grin is quite busy atm, so just need to be a little patient....
