My understanding is that field weakening is necessary to run a motor above it's rated speed by reducing the magnetic flux.
In a brushed motor the field winding current can be modified to reduce the magnetic flux, but with a brushless motor with permanent magnets, some electronic trickery is employed in the armature to push back the permanent flux, reducing back EMF and allowing higher speeds (less torque).
Is this bad for the permanent magnets?
Should I be judicious with the flux weakening settings on my controller?
I imagine the motor becomes less efficient and drains the battery disproportionately if pushed past its rated speed with flux weakening? Is this correct?
