When powering on my Kelly Controller KLS7245N, the key fuse kept blowing. Eventually I plugged the pin7 connector in after I allowed power to B+ and B-. The controller powered on fine, the key fuse fuse didn't blow and all was well. I then turned off the controller, but now it won't turn back on. Have I fried something in my controller?
Any help is gratefully received!
Have I fried my controller?!
Re: Have I fried my controller?!
Fuses blow for a reason. You didn't specify when it blows.
Does it happen under a load or even simply when you power the controller?
What motor is connected? What battery voltage are you using?
