TSDZ2 OSF for all displays, VLCD5-VLCD6-XH18, LCD3, 860C-850C-SW102.
Danger_Toast   1 µW
Re: TSDZ2 OSF for all displays, VLCD5-VLCD6-XH18, LCD3, 860C-850C-SW102.
Post by Danger_Toast » Apr 04 2021 12:00pm
Hey guys, just did the switch over from cashino's 1.0 and having a bit of trouble finding where I'm losing performance in the menu as there are fewer options.
I have a tsdz2 with 42t on the front, 7 speed on the back (i only use 3 of them).
My battery is 48w 14.5 ah
I've tooled around in power/hybrid/and torque modes, and I've noticed I'm not getting any motor assist past 240, and that it stops all together past 80 cadence (I thought .20 had the higher cadence option).
My motor settings are:
MV:48V
Power max: 500 (I tried 700 too, assuming it was saying max of human+motor but no change)
Acceleration: 35
Min ADC step: 1
Battery:
Max current: 14
low cut: 42
resistance 300
Anikea   1 mW
Post by Anikea » Apr 04 2021 1:39pm
Danger_Toast wrote:
Apr 04 2021 12:00pm
Battery:
Max current: 14
low cut: 42
resistance 300
Resistance ? What version do you use? In my mind in the 20.1c there ist no resistance.
Danger_Toast   1 µW
Post by Danger_Toast » Apr 04 2021 2:30pm
mbrusa wrote:
Apr 04 2021 1:37pm
Maybe you are in Street mode with 250W power limit.
Oh boy am I embarrased :/ thankyou lol.
Fixed the power, is the field weaking/high cadence thing about the same as 1.0, except for the fact it can't be disabled?
mbrusa   100 W
Post by mbrusa » Apr 04 2021 2:36pm
Field weaking cannot be disabled but is activated only when the maximum PWM value is reached (for this version 254 is displayed).
mbrusa   100 W
Post by mbrusa » Apr 04 2021 2:40pm
Anikea wrote:
Apr 04 2021 1:39pm
Danger_Toast wrote:
Apr 04 2021 12:00pm
Battery:
Max current: 14
low cut: 42
resistance 300
There is no battery resistance only for the stock displays version.
Mr.Flibble   1 W
1 W
Post by Mr.Flibble » Apr 05 2021 12:53am
mbrusa wrote:
Apr 01 2021 2:37am
Mr.Flibble wrote:
Mar 31 2021 4:42am
I have stripped the motor, dried everything out, re-greased, physically calibrated the torque sensor and reassembled. But it is still ghost peddling after a while :(
As It's fine when I test it on the flat, I suspect its heat acting on a dry controller joint.
Anyone got any other ideas?
To better understand what it depends on, you should take a test in Power assist mode with:
Min current ADC step = 0
Assist w / o pedal rotation = disabled
Startup boost = disabled
If it still fails, immediately check the Pedal torque delta and Pedal cadence values ​​in the Technical menu.
I have done this (but in EMTB mode).
When it's working fine the torque sensor registers 0.
When it's ghost peddling is registers 4-6.
maximusdm   100 W
Post by maximusdm » Apr 05 2021 2:29am
I did a test of 40km on LCD3.
I used simple power mode with no boost just basic. I tried to put the motor to stress by keeping it for a while between 40-50 km/h with a top speed of 53, on flat with standard 42 gear.
Motor feels definitely more powerful at higher cadence since it was not possible to keep this speed before for me. At 40-45km/h for a few km the temperatures settled around 49C at outside temperature of 15C. This looks ok to me, similar to older versions with thermal pads installed.
However after 30km the battery died completely even my watthour counter showed only 300wh consumed out of 630wh. Also the battery indicator never works fine even after a full charge is not full bar. This is a serious problem if I can not count on my battery range.
I think that the voltages are messed up in LCD3 and thus the weird behavior like Elinx said. I will do an other test to make sure.
@Mbrusa Do you have an LCD3 to check if the problem is reproduceable for you too?
mbrusa   100 W
Post by mbrusa » Apr 05 2021 4:28am
No unfortunately I don't have an LCD3 to test.
In any case, it is a problem to be investigated.
The consumption in Wh e and the battery bars are controlled differently in the three versions.
- VLCD5/6, XH18
The calculation of the Wh used is done in the controller. I found a difference between the calculated Wh and those measured with an external instrument, this difference is compensated for in the code.
The battery bars are calculated with reference to the voltage, so they may not correspond to the SOC%, but it is possible to correct them by changing the values ​​of Cell x / 4 or Cell x / 6 in the configurator. It is also possible to manually reset the SOC% in case you put a not fully charged battery.
- LCD3
The calculation of Wh and bars is in the LCD3 code and has remained that of the original 20beta1. I have not made any checks on the correspondence of the calculated Wh.
Also in this version, the battery bars are calculated with reference to the voltage, but if there is no correspondence with the SOC%, a correction is not possible.
However, it is possible to enter the effective capacity and have a precise SOC%. But this in all versions.
If you put a not fully charged battery, a manual SOC% reset is not possible.
- 860C
The calculation of Wh and bars is in the 860C code and the same as in v1.1.0 remained, here too I found a difference between Wh calculated and measured, but I did not foresee any compensation.
The bars of the battery are calculated with reference to SOC%, they are therefore very precise, as long as the real value of the capacity is entered and the battery always fully charged.
If a not fully charged battery is inserted, a manual reset is required, otherwise SOC% and bars are not updated. The logic of the manual reset is different from that of the stock displays.
Perhaps it would be better to standardize the versions with regard to SOC%, Wh consumed and battery bars.
Now I ask those who use LCD3 or 860C and have an external wattmeter if they find differences by comparing the consumption.
What are the preferences for calculating bars, referring to voltage or SOC%? There are pros and cons.
Waynemarlow   10 kW
Post by Waynemarlow » Apr 05 2021 4:58am
Keep it simple, relying on entering precise values for total W/h’s, reliance on fully charging a battery and using the same battery ( I have 3 all using different cells and total W/h’s ) each time makes me vote for simple voltage level only on the battery bars and an alternative SOC reading customisable to your battery for those who want that extra bit of info.
casainho   100 GW
Post by casainho » Apr 05 2021 5:00am
mbrusa wrote:
Apr 05 2021 4:28am
- 860C
The battery SOC I implemented on 860C and SW102 is even more complex than this, it includes the battery resistance value that is configured on the display.
To have the correct SOC estimation, user will need:
- use the automatic measure of battery resistance done by the 860C and SW102
- make the battery low voltage configuration very low to use the max real capacity of the cells
- fully discharge the battery and see the counted value of capacity in Wh
Also be aware that battery resistance can change a lot with ambient temperature and so will SOC also change. Like SOC at 0 degrees or SOC at 35 degrees ambient temperature, may change like -+ 20%.
- EBike wireless standard: wireless motor, wireless cycling GPS display Garmin Edge and wireless remote with wireless brake sensor
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless EBike standard ANT+ and Bluetooth, TSDZ2 OpenSource firmware, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
Please consider a donation to help developments: paypal.me/jorgecasa
mctubster   100 W
Post by mctubster » Apr 05 2021 5:53am
maximusdm wrote:
Apr 05 2021 2:29am
I have also noticed a discrepancy for SOC on my 860c running 0.20c ... I also run an external coulomb counter ... with the external coulomb counter at around 20% capacity left, the 860c is showing 33%.
I just double checked my coulomb counter and it seems I de-rated the battery in that by more than I remember ... the 860C has 650Wh configured, the coulomb counter 16.6Ah or 614Wh (@ 3.7 nominal) so the error is slightly higher again, about 15% out.
I will check settings and test again, but likely a week to use a full battery.
maximusdm   100 W
Post by maximusdm » Apr 05 2021 8:46am
mbrusa wrote:
Apr 05 2021 4:28am
- LCD3
I use the validated real battery capacity in WH = 630, inserted in battery menu. It worked fine and the precision is to the procent.
Indeed the battery state in the left corner seems to be Voltage rated, but has also internal resistance set as well (130).
I think that the Voltage difference that Elinx was talking about is the root of all evil.
1. The cut out voltage is wrong and cuts the motor power.
2. The power outputted on display is smaller than in reality and thus the higher temperature on a similar watt usage on display.
I really do not understand how Buba volts are smaller than Mspiders volts :))). These formulas are 200 year old, and do not see how same things can have different values, no matter the implementation.
mbrusa   100 W
Post by mbrusa » Apr 05 2021 1:44pm
If you check the real battery capacity and enter the real value, the SOC% will be accurate in all versions.
The Wh consumed instead, for different reasons, may be lower than the real ones.
maximusdm wrote:
Apr 05 2021 8:46am
The volts of Buba are the same as those of Mspiders, it is the Amps that are smaller :D
mbrusa   100 W
Post by mbrusa » Apr 06 2021 1:51am
Mr.Flibble wrote:
Apr 05 2021 12:53am
mbrusa wrote:
Apr 01 2021 2:37am
Mr.Flibble wrote:
Mar 31 2021 4:42am
Your torque sensor changes value as the temperature rises like everyone, yours is probably more sensitive.
The advice to try with Power assist, I did not want you to change the mode you use, but only to have a confirmation that only depends on this.
You should solve by calibrating the torque sensor, increasing the "Pedal torque offset" value obtained from +5 to +10.
However, this affects all modes.
eMTB has a dedicated offset with value -10, the problem could occur with sensitivity eMTB > 12.
I can also just change eMTB offset and send you a modified version to try.
Waynemarlow   10 kW
Post by Waynemarlow » Apr 06 2021 7:00am
Went out on a good ride with a couple of friends on a Levo and another TSDZ2
Screenshot_2021-04-06 Epic spring Morning Ride E-Bike Ride Strava.png (9.43 KiB) Viewed 241 times
Interesting comparison between the Levo and the TSDZ2 in that we seemed to be drawing much the same W's for all the climbing with the Levo max at 744W and an average of nearly 200W's, On all the ride he used 370Wh's over the 990m of climb
On my 48 volt motor 52 volt battery, unmodified for heat dissipation TSDZ2 on V20.1C LCD3, unfortunately I don't have a max reading, but mine is set at 700W's max but on the display I saw regulalry 450W's and sometimes pushing into the 600W's and used 420Wh's. Now the Levo rider is fitter and lighter and the 50Wh's could easily be explained by the 15kg difference between riders.
The most interesting for me was the other TSDZ2, a 36 volt motor on 48 volt battery, modified with a sleeve around the motor filling the gap between case and motor and heat transfer grease to fill any voids between motor - sleeve - case. Again on V20.1C LCD3 but nowhere as physically fit rider but again 15kgs lighter, using only 340Wh's.
Those little 36 volt motors are great motors and I'm thinking of dropping back once I have an 8 pin controller with a temperature sensor on board.
Nfer   10 W
Post by Nfer » Apr 06 2021 7:33am
Waynemarlow wrote:
Apr 06 2021 7:00am
Interesting. Do you guys have the boost option enable?
Waynemarlow   10 kW
Post by Waynemarlow » Apr 06 2021 7:50am
Yes with Boost but no to rotational.
maximusdm   100 W
Post by maximusdm » Apr 06 2021 10:03am
mbrusa wrote:
Apr 05 2021 1:44pm
I am not sure what you mean by SOC %. Is it odo field or battery segments?
If I set the Wh in menu 1, the battery percentage from odo field is obtained by subtracting the consumed wh for the total wh. And so the percent is wrong because the consumed wh are wrong. For the battery segments i know is calculated based on voltage and internal battery resistance set in menu 1, but still this does not work fine since it is missing one segment with fully charged battery.
Any idea how to fix the amp difference? From what I saw in code, the display should only show the values sent by motor, not recalculate them. I can try to test some modifications, just don't have a clue where to start.
Waynemarlow   10 kW
Post by Waynemarlow » Apr 06 2021 3:34pm
maximusdm wrote:
Apr 06 2021 10:03am
We have 1 controller that reads the voltage incorrectly, always under reading and hence the top bar is never shown. Wasn’t the version for the VLCD5 able to put in an offset to correct the voltage level ?
James Broadhurst   100 W
Post by James Broadhurst » Apr 06 2021 4:43pm
Well! with 52v battery & 48v motor and 850C was a revelation. Superb piece of work. Approx 6wh per km over 40km @17kph av over gentle road with one big hill which I thrashed up it with the temp staying below 30 (very cold here for us - just above freezing but wind chill at least -4) All on a 29er
Having read that it was worth trying the LCD3 I tried it with a 48v battery and motor on 28” Boardman hybrid. That was very special! Not done the power consumption but it’ll be slightly greater than the 29er but faster. Temperature the same.
And the lights! Watching the reaction from motorists behind as the lights blinked away with the brakes on was a hoot!
Both bikes on V20.1C running Hybrid mode.
There are a number of quite dangerous minor road junctions here where you’re joining from a lane onto a road with vehicles travelling at 70mph round a blind bend. Having a reliable and fast start is so much safer. Well done to all who made this software happen.
mbrusa   100 W
Post by mbrusa » Apr 07 2021 1:48am
maximusdm wrote:
Apr 06 2021 10:03am
mbrusa wrote:
Apr 05 2021 1:44pm
SOC% is the battery capacity in percent.
Maybe I was misunderstood, the consumption in Wh displayed is not wrong, the 20% difference in the current / power calculation is only in the 20 beta 1 version.
To get the exact percentage, calibration is required.
I can't check it on the display, I read from the manual:
1.5 - Enabled (1) 100% -> 0%
1.7 - Total actual battery Wh
1.8 - Wh consumed
Fully charge the battery, the consumed Wh is zeroed.
At this point, use the bike until the battery is completely exhausted.
Check the Wh consumed 1.8
Set the actual total Wh of the battery 1.7 with the value of the consumed Wh.
The remaining battery capacity (SOC%) can be displayed in the odo field (option 2.1), or if you prefer in the temperature field, I believe it is at the bottom right of the screen, set menu item 8.10 to (2).
The battery bars with LCD3, are based on voltage, they cannot be precise, you should be able to set a voltage value for each bar as you do in the version with configurator.
maximusdm   100 W
Post by maximusdm » Apr 07 2021 8:00am
mbrusa wrote:
Apr 07 2021 1:48am
1.8 - Wh consumed
Thank you for the clear explanation.
The procedure explained is exactly what I use for more than 2 years. I will redo de calibration and come with the results.
Just that my battery is 48v/17ah so aprox 816Wh. The real measured value by checking the consumed watts is 630Wh on 0.20.beta1.
I hope that the same value can be use also in current version, because in my latest test the consumed Wh was aprox 350wh much smaller than my battery.
Mr.Flibble   1 W
1 W
Post by Mr.Flibble » Apr 07 2021 11:09am
mbrusa wrote:
Apr 06 2021 1:51am
Mr.Flibble wrote:
Apr 05 2021 12:53am
mbrusa wrote:
Apr 01 2021 2:37am
Mr.Flibble wrote:
Mar 31 2021 4:42am
That's very kind of you, but I have ordered a new controller as it has locked up, and gone off all by it's self.
If it was just a change in readings with temp, surely restarting would reset "zero" and fix it?
mbrusa   100 W
Post by mbrusa » Apr 07 2021 11:27am
Mr.Flibble wrote:
Apr 07 2021 11:09am
Yes, with the restart the zero is reset, but only with "Torque Calibration" disabled.
